Old 01-20-2006, 09:58 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Question about throttle body
I cleaned out my throttle body the other night (first time with my new car). Cleaned it with throttle body spray. It was pretty ugly. After cleaning it, it looked brand new. Got everything hooked back up (and yes, it's all properly hooked up), started her up and drove her around...An hour or so later i get a CEL. Take it to autozone to have it read and it throws something like "Idle air malfunction" or something like that. I triple checked to make sure all connectors/vac lines were on. Everything is fine, but i'm still getting the CEL. I never got it before i cleaned out the TB.
The book the guy looked at had a couple different reasons for that code. The 1st reason was "engine vacuum leak". 2nd was "Idle air control". and i can't remember the others.
Any ideas?
Old 01-20-2006, 10:01 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Re: Question about throttle body
The IAC could have got some TB cleaner in it, and it could have made the sensor malfunction change it and see what happens.
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 01-20-2006, 10:07 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
yeah that's what happened to me once,
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 01-20-2006, 10:10 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
did you take it off to clean it? if so did you use a new gasket when you put it back? if not you probably have a vac leak
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
