I've been saying I was going to do this thermostat for a while now but I'm finally getting to it. So many interuptions (rain, work, and skool) So before I go under there this weekend (no interruptions, off from work and its supposed to be clear blue skies) I need some help. What do I have to do to get to the thermostat. The Haynes manual says I need to drain the radiator but everyone else says I don't.
Not only that the Haynes manual doesn't give a location for the thermostat. I have a feeling where it is because I've done one but it wasn't a Tercel. So it anyone can help me with this it'll be really appreciated. |
Re: 91 Tercel Thermostat
Thanks. For reminding me to buy a gasket.
I bought a thermostat but it came with a gasket attached to it. Would I need another gasket for somewhere else that I don't know about yet? 15min at the worst works for me. I know how to take things apart and put them back together easily. So HOPEFULLY it wont take that long. |
Remove the dist.
Thanks for that info, the Haynes manuel doesn't give any additional info like that. |
I just did the girlfriends 90, didn't pull the dist or unhook the cooling lines.Makes a mess no matter what you do, but do drain the rad. |
I don't know if you finished your job, but I did mine yesterday. To pull out thermostat, l drained the rad, take off one hose(the big one from the buttom of the rad), uncliped one connector behind, and I confirm that it is 2 10mm bolts on the cap. The thermostat is behind this cap, under the distributor. Have a good work !
O yea I did finish it and everything you said was just how it is. My old thermostat was ruined, I wish I could put a pic up of it but I threw it away. The only difference is that I took off the distributor so I could get to it easier.
