Old 01-20-2006, 05:17 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Exclamation Engine problems
I just bought a 1990 crx for 3k. It has a B16a engine swap.
My friend has the same swap in his crx.
My problem is the engine idles at 1800 and the tach bounces at 7000.
the only thing different from his engine and mine is the ecu's.
he has a pr3 and I have a pw0.
I don't know what to do please HELP!!!!
Old 01-20-2006, 08:31 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Re: Engine problems
Does tach bounce from 1800-7000? if so sounds like a vacumn leak.
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 01-23-2006, 04:53 PM
Re: Engine problems
the engine will idle at 1800, the throttle response is great all the way to 7000 rpm's, but then it won't go to 8000rpm's. i checked the vaccum lines and the only thing different between my friends engine and mine is the ecu.
my ecu is a pw0.
do I need a pr3?
Old 01-24-2006, 01:48 PM
Exclamation Re: Engine problems
please help me!!
I was looking around and saw that the ecu I have is what i need.
I think the problem is my tach. i think it's 1000 rpm's off how do I fix it?????
Old 01-24-2006, 02:00 PM
justin476 justin476 is offline
Re: Engine problems
I think the pwo is actually better than the pr3. If you still think it's the ecu try switching with your buddy..see if that changes anything. If not you definetly know it's not the ecu...just a thought...
Old 01-24-2006, 10:23 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Re: Engine problems
you should be able to tell if the engine is at 800rpm of 1800 just by how it feels and sounds.
Old 01-25-2006, 02:10 PM
Re: Engine problems
we will try swapping ecu's if that doesn't work,
what ecu should I buy for the car and where????????
Old 01-25-2006, 04:27 PM
Hybrid1990crx's Avatar
Re: Engine problems
for the high idle look under the throttle body and you'll see a cylinder looking thing. take it off. take it apart. inside there is a ball that can be screwed in. screw it all the way in nice and tight. put it back together and bam no more high idle.
i had the same problem with my b16 but mine was idleing at 3k.
Old 01-26-2006, 11:17 AM
Re: Engine problems
hey hybrid crx do live in the diego area? I could bring the car by and you could look at it and let me know what's wrong.
Old 01-26-2006, 08:51 PM
Re: Engine problems
nah dude lol im on the east coast
