Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-20-2006, 03:35 PM
ChrisGood's Avatar
ChrisGood ChrisGood is offline
Occasional/ intermittent rough idle and loss of power
I have a 2000 GMC JIMMY which suddenly has developed a stutter...lol
It will drive fine for a while then suddenly you stop at a light the idle drops low and when you go to start off it bucks and jumps and acts like it is going to die. It started doing this a while ago so I cleaned the maf, replaced the wires, the plugs have maybe 10k on them, replaced the fuel filter, cleaned the throttle body. Thought it was fixed and now it is doing it again, not nearly as bad as before but still its not right. After the little tune up I did it did get a lot of its power back that it had slowly lost over the last few years but I know there has to be something more. I am thinking rotor and cap but not sure, and if not then what?
I can fix anything, if you just tell me how.
White 2006 Chrysler Town & Country
Zurich Pearl White 1993 3000GT VR4
1993 3000GT VR4
Old 01-20-2006, 07:45 PM
Slow_n_ez Slow_n_ez is offline
Re: Occasional/ intermittent rough idle and loss of power
Hummmm .. sounds like its gasping for air ... change the air filter was probably done at same time as fuel filter .... My pickup use to do same thing , however the cause was traced to a air leak in the fuel line .... just enough of a leak to make the dirt wet but not soaked or dripping .... I read also through the threads that some valve in the exhaust pipe manifold will malfunction and close ,therfore choking off air that needs to be pushed out
Old 01-21-2006, 01:11 PM
old_master's Avatar
Advisor/Moderator
The distributor cap and rotor should be replaced at each tune up and as necessary between tune ups.
Check the EGR valve. Remove it and clean the passages in the valve and intake manifold. Install an upgraded gasket between the EGR valve and intake manifold. It has a screen in it designed to break up carbon deposits that are dislodged from the combustion chambers. Any GOOD auto parts store will have it.
Old 01-25-2006, 09:34 AM
ChrisGood's Avatar
it seems to have stopped, think maybe it just needed to adjust a little after all the work was done to it?
1993 3000GT VR4
