Old 01-20-2006, 03:34 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Horn trouble
Alright, my horns are not working. I searched the forum, but none of the other problems seem like mine. I used my horn earlier today, and it worked fine. I get home, and push "LOCK" on my key fob twice, and no honk. So, I open the door and push the horn button, nothing. Then, I hit the panic button on my fob, the lights all start blinking, but no horn. I got under the hood and checked to ensure my horns were still plugged in and they were. I took the horn relay and switched it with an identical relay on the block, and I still got nothing. Now, i am stumped. Anyone have any ideas?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 01-20-2006, 03:54 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: Horn trouble
Did you check the fuse? If the fuse is good run a jumper wire down to the horn and touch it to the positive side and see what happens. If no honk then bad horn, if honk then start chasing the wires, fuse, and relay.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 01-20-2006, 04:06 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Horn trouble
One of mine stopped and I had to replace it.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 01-20-2006, 04:09 PM
Re: Horn trouble
The relay's good, is there a seperate fuse? I couldn't find one if there is
Old 01-20-2006, 04:28 PM
chuck16's Avatar
chuck16 chuck16 is offline
Re: Horn trouble
it's weird that both of your horns have gone out. That would indicate something electrically. However, that being said crawl under the passenger side and lookup. You should see the passenger side horn. Disconnect and remove it then hot wire and see if it works or just hot wire it in place. Also, get your wife to press the horn but with a test light and see if your getting voltage at the horns...
Happy hunting...
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 01-20-2006, 04:33 PM
Re: Horn trouble
I'm a friggin idiot... I didn't see on the chart that there was a seperate horn relay and fuse. The damn fuse was blown...
Old 01-20-2006, 05:03 PM
chuck16's Avatar
Re: Horn trouble
Doh! Question is why did the horn blow?
2008 GMC ACADIA
I AM Canadian!!
Old 01-20-2006, 05:13 PM
Re: Horn trouble
U mean the fuse? No idea. We'll see if it does it again, and then I'll worry
Old 01-20-2006, 05:22 PM
chuck16's Avatar
Re: Horn trouble
Yeah Could have just been water in the horn...
2008 GMC ACADIA
I AM Canadian!!
Old 01-20-2006, 05:27 PM
Re: Horn trouble
I did just wash my engine bay
Old 01-20-2006, 06:04 PM
chuck16's Avatar
Re: Horn trouble
Ahh Perhaps that was the culprit.
2008 GMC ACADIA
I AM Canadian!!
Old 01-21-2006, 10:33 AM
kmschna kmschna is offline
Re: Horn trouble
My horn fuse will blow everytime I lay on it over a full second. I have now learn to give 2 small beep when required. Otherwise, I'll be replacing the damn fuse again.
I would appreciate anyone insight as to why the fuse blows all the time. Perhaps a higher amp fuse? Or might this cause additional problems.
Thanks
Old 01-21-2006, 05:16 PM
airpanefixr's Avatar
airpanefixr airpanefixr is offline
Re: Horn trouble
Thanks
DO NOT up the fuse amps!! If that wire is overloading that it's blowing the fuse then the wire bundle going from that fuse is to your horn system is going to catch fire or at least burn up
Old 01-21-2006, 10:20 PM
rrousou rrousou is offline
Re: Horn trouble
Thats one way to get a new truck and fix the problem at the same time
