Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 01-20-2006, 12:52 PM
AUTOUSA's Avatar
AUTOUSA AUTOUSA is offline
Cool 1997 Maxda 626 4 Cyl. Manual!Check Engine Light is flashing!
1997 Maxda 626 4 Cyl. Manual!Check Engine Light is flashing!Hooked up a scanner and there is no code.Vehicle does ocassionally jerks and stumbles under heavy accelariation.I think something is unpluged but so far no luck.If anyone has any ideas please help!
Old 01-20-2006, 06:05 PM
rjitzsu rjitzsu is offline
Re: 1997 Maxda 626 4 Cyl. Manual!Check Engine Light is flashing!
flashing MIL means type a misfire... a misfire that could cause damage to the catalytic converter. Check spark plugs and wires for arcing... most likely the cause on this model.
Old 01-22-2006, 02:06 PM
AUTOUSA's Avatar
Unhappy Re: 1997 Maxda 626 4 Cyl. Manual!Check Engine Light is flashing!
Changed spark plugs and checked wires and etc...
Then I reset it by leaving positive off for 10 minutes.Chenk engine came on and it was steady less than minute after i started the car.Car feels running better now .Now I can check code to.i got speficific manufacturer code :P1195
SCP HBCC Chip Failed To Initialize
it looks I have hit dead end.Researched every single forum on the web and no help.
Old 01-23-2006, 08:15 AM
diagnosticmonkey diagnosticmonkey is offline
Question Re: 1997 Maxda 626 4 Cyl. Manual!Check Engine Light is flashing!
hey all, new guy here. MY idle cuts out on deceleration on my 94 626. the tps is not quite within spec, checked for vacuum leaks and no check engine lite is on, however at times flickers. idles good cold but after warm up it idles back and forth on slow down and stops, then recovers and were good til the next stop lite. Question , could the tps voltage being off.3 volt really make that much difference. Appreciate any info, thanks Bruce
Old 01-23-2006, 08:20 AM
HOWDY, My lite also goes on and off from time to time. Im finding my TPS to be out .3 volts when at idle. I played with the adjustment and got it to smooth out and lite is out, however upon decel I notice a variable idle condition and cruising a slight pulsating motion. Any help would be appreciated. thanx Bruce
Old 01-23-2006, 09:04 AM
AUTOUSA's Avatar
I thought we are trying to solve my problem.
I guess all of these 626 mazdas have that problem.
Old 01-30-2006, 06:54 PM
autousa,
p1195 is a boost sensor code.
check for kinked or, more commonly, broken vacuum lines leading to the boost solenoid and sensor. the boost sensor solenoid and prc solenoid connectors are interchangable... so make sure they're in the right place. (orange connector goes to boost sensor).
