Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 01-20-2006, 10:12 AM
DeeDub90 DeeDub90 is offline
Will Not Burp!
1995 Sonoma 4x4 SLE
The annoying slurping/gurgling sound in dash is starting to kill me! I've flushed system, replaced cap, raised front end of truck and ran with rad cap off and yet the noise will not go away!
Is there a way to purge out the air right at the location it is stuck, like loosen the hose or something?
Any suggestions!
Old 01-20-2006, 11:08 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Will Not Burp!
Loosen up the heater hoses at the firewall with the engine warm and running but not hot and let the coolant squirt out some.
It may help and my not but it will bleed the heater core.
Are you sure it is coolant in the heater core and not the air cond everator making the noise?
MT
MT
Old 01-20-2006, 11:46 AM
Re: Will Not Burp!
How do I know if it's air cond., what should or could I check? Maybe it's that?
I believe it's the coolant though because it does it when I take off from stop and I can hear it gurgling and when I come to a stop also (like it trickles down, gurgling). When I get off hiway and come to stop, I can hear it, sounds like boiling water....GLUG..GLUG!!!.
Old 01-20-2006, 12:00 PM
MT-2500's Avatar
AF - Advisor
Re: Will Not Burp!
Try bleeding the heater core and to make sure it is not the air cond just unplug the compresser for a test drive.
Good Luck MT
MT
Old 01-20-2006, 12:21 PM
Re: Will Not Burp!
I will try it this weekend and post results! Thanks for help!
Old 01-21-2006, 02:31 PM
Re: Will Not Burp!
Unplugged compressor....still does it!!!! Gonna try other on Tuesday!
Old 01-24-2006, 05:45 PM
Re: Will Not Burp!
Anyone know a ball-park $$$$ to replace fuel injectors!
Old 01-24-2006, 06:03 PM
MT-2500's Avatar
AF - Advisor
Re: Will Not Burp!
You did not say what engine and engine code exc. Lot of difference there.
If you are having a repair shop do it have them give you a estimate.
If you are doing it yourself ask parts place how much.
MT
MT
Old 01-24-2006, 06:50 PM
Re: Will Not Burp!
4.3L V6 Vortec Engine
Its in repair shop now and they said about $800 CDN just for parts!
He said engine codes are: it's running LEAN
Old 01-24-2006, 09:12 PM
MT-2500's Avatar
AF - Advisor
Re: Will Not Burp!
Aw man.
Something does not add up on eng code lean and replacing all injectors.
You need to get a second opinion on that deal.
MT
MT
Old 01-25-2006, 04:42 PM
Re: Will Not Burp!
These are the codes:
P0141 and P0171
Old 02-23-2006, 03:41 PM
Re: Will Not Burp!
Well, replaced injector and no more check engine lights!!! Fixed problem!
Tried to remove air from lines though....still there, but not as bad! Maybe it will take 52 tries....lol!!!
Old 02-23-2006, 04:31 PM
MT-2500's Avatar
AF - Advisor
Re: Will Not Burp!
Drive it a little and retry.
At least you got that check engine light fixed.
Thanks for posting back and letting us know how it is going.
MT
MT
