Old 01-20-2006, 09:51 AM
Deadboy's Avatar
Deadboy Deadboy is offline
Send a message via MSN to Deadboy
Gas tank question
I have had a carbed engine but now i have a fuel injector engine....the service manual says that the fuelpump is in the tank...but my carbed motor tank does not have it caz the engine sucks the fuel from the tank.....soo the questin is do i have to buy a new tank with the pump or is there a noter way?
Old 01-20-2006, 11:57 AM
Deadboy's Avatar
Re: Gas tank question
anyone?
Old 01-20-2006, 01:51 PM
1991HB 1991HB is offline
Send a message via AIM to 1991HB
all you have to do is go down to the parts store and buy a new fuel pump. You can take the fuel pump out of the gas tank and switch it.
Old 01-20-2006, 03:29 PM
duffman868 duffman868 is offline
was there a model w/ fuel injection? because in the us the 3rd gen civic came with both and the si came with fuel injection and the others came with carbs. what you needed to do with those was get the external pump from the si. if the wasn't fuel injected model then order an aftermarket external one and put it on there just remember to upgrade to high pressure hose
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 01-21-2006, 01:03 AM
Deadboy's Avatar
the thing is that the tank does not have a fuel pump system...i can see the shape were the fuel pump should be but it not cut...it like they made fuel pump spot but forgot to cut it. And if i was to cut the hole fot the pump i may leak.
Soo best way to go is get a tank with the pump ....or could i just put the pump somewear els?
P.S Carbed engines had the pump build by the engine ...it was a vac. pump
Old 01-21-2006, 08:46 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
dude...I suggest getting a tank with the pump in it...and the pump you had on before is called a "Mechanical Fuel Pump", I thought ther work off the head of the motor over a rocker...but I guess they had Vac to dont really have a book to find out and my dsl is down and dont feel like searching on 56k...the fuel pump located bac on pasenger side of the gas tank...its not the sending unit that sits right in the middle of the car if you where to remove seat or cargo area depending if you have a hatch or crx...
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 01-21-2006, 10:04 AM
Deadboy's Avatar
Yes i know were it is or should be located......so i got me a 91 civic Si tank....looks the same as mine but had the pump and sending unit.
Got it for 30$ + all the SI interior wires (uncut)
So now its back to work on the car
Thx for the inf tho
