Old 01-19-2006, 04:39 PM
ashypoo86 ashypoo86 is offline
Grinding Noise when I turn wheel
Lately, whenever I turn the steering wheel, i hear a Rrrrrrrrrrrrrrrrrrrrr grinding noise only when I turn, What could be my problem? Could it be a bad wheel bearing?
Old 01-19-2006, 06:21 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Grinding Noise when I turn wheel
Hey ashypoo86. From what you are describing it sounds lik the bearing/hub assembly. You'd probley want to get this fixed asap! Could lock up the wheel if it gets to badly worn.
They are expensive though depending on where you liv, around 110$ each, and you really should change both fronts at the same time to prevent premature wear on the old bearing/hub assembly.
I guess it could be your brakes too, but they tend to grind when braking or all the time. Does it grind more when you brake? If so it might just be the brakes need replaced. or does it stop when you brake? That would be the bearing.
Hope this helps, let us know if you hav more trouble.
1999 Grand Am SS 3.4 OHV
Old 01-20-2006, 12:38 AM
zirb zirb is offline
yep its the hub. Just had to change mine on a 99. Was making the same sound. Got mine from National Auto parts. 1-800-428-4300 $95.00. Napa shot me a price of $250.00 Gm was $279.00. The one from National was a timken.
Old 01-20-2006, 02:13 AM
icemike89 icemike89 is offline
Mine does that on really cold starts but goes away when my car warms up. It could be the power steering pump because at the same time there is like a whining noise coming directly from my ps pump when I press the throttle. Both noises go away within minutes of driving
Old 01-22-2006, 08:43 AM
chrisbmechanic chrisbmechanic is offline
check the power steering fluid first my 2001 was doing that and i need fluid but thats all it took ok
