Old 01-19-2006, 03:50 PM
The Sheene Machine's Avatar
The Sheene Machine The Sheene Machine is offline
Unhappy Tamiya 206 WRC kit...Has anyone else had this problem?
Ok, so I'm building my first 206 kit - all very nice but...I'm prepping the body for paint - sanded all seams but I'm having trouble removing one...runs from the hood across the wing to the outer corner of the wing where it meets the bumper, kinda runs diagonal just above the headlamp - drivers side. After using 800/1500 grits it looks fine but once the primer is on it is still visible - I tried brush painting some dark paint on it , then sanding to see if there is any low spots. Nothing. Coat with primer - still there! I tried putty and the 'indentation' is not deep enough to take it. I tried heavier coats of primer, still there More sanding with 800 grit, primer, still there I guess it sort of leaves a shadow??
I noticed on Marcus Nichols biuld of the kit in issue 84 of TMMI, this seam is visible on his model too ( if you have it check photo on front cover, just runs under Esso decal).
So - anyone else found this or have I lost the plot!?
Paul
On the bench;
2003 LV Rossi Honda RC211V
Old 01-19-2006, 04:12 PM
jdmmonkey's Avatar
jdmmonkey jdmmonkey is offline
Re: Tamiya 206 WRC kit...Has anyone else had this problem?
some pics would help =)
Old 01-19-2006, 04:16 PM
RallyRaider's Avatar
Zomby Woof
Can't say I've had the same the problem on my three 206 builds. Sometimes laquer primer can etch into the different grain around a sanded down seam and make it reappear. Usually repeated coats of primer will fix the problem in my experience. I also find super glue is good for a quick filler of small indentations and seams. What kind of primer are you using?
Old 01-19-2006, 04:30 PM
Hopefully you can just make this out...the seam (really it's a faint shadow) is just above the headlamp 'hole'. Primer is automotive plastic primer - UK company called Halfords.
Paul
Paul
On the bench;
Old 01-19-2006, 04:32 PM
Vric's Avatar
Vric Vric is offline
It's quite small.. if you can't send it, try fine putty and resend.
Old 01-19-2006, 04:48 PM
Zomby Woof
Hard to see but I can just make it out. I'd brush some more primer on there or wipe some superglue over it then sand back and prime again.
I'm guessing the Halfords is straight from a can? Might help explain the etching, since a spraycan tends to lay a thicker wetter coat with more solvents that can eat into the paint and plastic beneath. Using an airbrush allows you to lay down thinner, dryer coats that might help fill the seam without it ghosting like that.
Old 01-20-2006, 12:04 PM
Thanks Phil - I'm just in the throws of trying the superglue route, hopefully this'll work. I'll post some pics later.
Paul
Paul
On the bench;
