Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-19-2006, 02:40 PM
aztecf aztecf is offline
99 Fan Stuck On High
1999 Suburban, fan stuck on high, will not change speeds or turn off when off is selected. Rear heat and fan work fine. ANY IDEAS???
Old 01-19-2006, 04:41 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: 99 Fan Stuck On High
Could be a relay.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 01-20-2006, 10:22 AM
777stickman 777stickman is offline
Could be either the switch or high relay. If it's running with the ignition key "off" it's the relay. If it runs with the key in the "run" position it's probably the switch.
Old 01-20-2006, 11:28 AM
Old Dave Old Dave is offline
My son just replaced the fan switch on his 98 K2500 and he got the switch at NAPA for $20. I was surprised that they had it, I figured that was a dealer only item.
1970 GMC 2WD shortbed fleetside
1984 Olds Delta 88 (won't die)
1997 GMC Suburban K1500 W/5.7L Vortec
2000 Dodge Ram 1500 4WD Shortbed Ext. cab
1998 Chevy K2500 W/5.7L Vortec
2002 Harley Custom Chopper
Wife is a late 1951
Old 01-20-2006, 03:03 PM
The switch was bad, it had partially melted.
Thanks Jeff
