Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 01-19-2006, 02:32 PM
Della33 Della33 is offline
Exclamation red fluid leaking?
NEED HELP ASAP!
Red fluid leading from front of 01' Intrepid. Dripping onto parking lot from driver's side at very front of car, looks like fluid also accumulating in pan under radiator. Driver's side only. The fluid looks "thick" and the puddle of it on my employer's parking lot had water beaded up on it, so it's a little oily in nature.
What is this stuff, and where's it coming from?
Need help in diagnosing problem ASAP -- need to know if safe to drive! THANKS!
Old 01-19-2006, 11:51 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: red fluid leaking?
that red stuff is your engine coolant. Based on the location of where you describe sounds like it's leaking from the plastic coolant tank located on the driver's side strut panel, those are prone to leaking. Get that fixed soon or else you'll overheat and ruin your engine.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 01-20-2006, 12:27 AM
RahX RahX is offline
if its oily its probably tranny fluid or ps fluid. i *THINK* there might be a cooler for the ps there but you should have a shop look at it. you might need the rubber tranny lines replaced. ive seen the ps coolers rub on a bolt and leak too.
Old 01-20-2006, 06:40 AM
katana1981 katana1981 is offline
Send a message via MSN to katana1981
i would say trans fluid.. usually you'll need to change a hose that's it.. cost: less than 1$ if DYI. 15$ at garage
