Old 06-14-2002, 05:15 AM
DeK1 DeK1 is offline
Door Panel fabric replacement?
I was wondering if anyone knew where to buy something to replace the fabric on the door panels? Mine is fading and I was looking for something else i could buy to change it out, not another pice of fabric preferably though. Thanks.
Old 06-14-2002, 07:04 AM
MSilage's Avatar
MSilage MSilage is offline
Banned
Send a message via AIM to MSilage Send a message via Yahoo to MSilage
go to a sign shop and buy some vinyl and re-do the doors. do a search on here and it will tell you how to remove the carpeted panel.
Old 06-15-2002, 12:34 AM
xivera's Avatar
xivera xivera is offline
Check out your local fabric stores (ie. Joann Fabrics, Hancock Fabrics) for materials. They have vinyl! I got some myself to match the rest of my car plus some 1/4" foam for extra padding.
Also, check out the following links that are available in the I/A/S FAQ:
Recovering Armrests
Door panel carpet removal
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 08-24-2002, 05:30 AM
flatrimmer flatrimmer is offline
door panel fabric replacement
Door panel fabric replacement on most newer cars is kind of tricky. The door panel was moulded to look like several pieces but it is only one. The area where you want to replace is inset,recessed, to allow material to be contact cemented on and then cut, trimmed off about 1/4 inch wider than the "groove" and then tucked into the groove with a tool such as a putty knife .The tool must be very smooth and dull so as to not cut the material when you tuck it into the recessed area. As you tuck in the material you will watch it "dissapear "into the recess, hiding the edge you left a little long. I would leave the old material on and apply contact cement onto the material that you choose and also the old material on the door panel and allow to dry for 5 minutes. the new material is then applied, smoothed out with hand to apply pressure and bond,careful to not get wrinkles. The puty knife is the sort of traced around the recess with some pressure applied. this will indent the new material and let you see a "line where you must add 1/4 inch to and cut . this extra material is tucked into the recess all around the door panel insert until completely finished. Contact cement is normally applied with a paint gun and sprayed on . make sure the glue is shot into the groove or you will have problems later with the material coming loose. This is a job for your local auto upholstery shop if you are not real sharp! good luck
