Old 01-19-2006, 11:32 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Question differential whine
I had made a post about this not too long ago. Since then ive changed the fluid and put on a t/a aluminum cover. The whine is still there. Someone had mention tightening something somewhere....There is some play in the differential. While I am driving and I let off the gas I hear the whine, then if I just stick my foot back on the gas without progressing into it I can here the gear catch because there is slack. The whine only happens at cruising speeds when coasting. I can also hear the slack in the gears when I slow down and the transmission starts downshifting. And some of you may know the 700r4 doesnt have the most seemless of downshifts. Anyways is there something that I can tighten or adjust?
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 01-19-2006, 11:34 AM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
Re: differential whine
x2....thats a good question....i have the same problem lol
Old 01-19-2006, 12:03 PM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
i think its just gonna keep whining.... i just started to ignore mine after a while.
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 01-19-2006, 12:23 PM
Link85x Link85x is offline
You know, when i install the rear, i thought mine was whining aswell. Took me 2 days to figure out where the hell the noise was coming from. My ebrake cables where fulling attached to the underbody and where dangling on top of the driveshaft. Thank god the shit didn't wrap around. Could've been gameover...
87 IROC - R.I.P, and she will never be forgotten
90 RS - The beginning of a new era... I hope.
Old 01-19-2006, 12:53 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
tall gears wiil whine, persnally, it's music to my ears otherwise, backlash is out adjustment
Old 01-19-2006, 12:57 PM
....hmmmm.....i dont think thats my problem but it sounds possible when i think about it....the ebrake cable thing that is....doesnt explain the slack. I turned the drive shaft when I had it on the ramps and with my hand I could move it about a 1/4 to 1/2 of an inch in rotation.
how is backlash adjusted?
Old 01-19-2006, 12:58 PM
I only have 3.23's I think....i tried to look when it was all apart but I saw no markings anywhere.
Old 01-19-2006, 01:02 PM
666_speed's Avatar
Son of Satan
i've got 3.08's blah......yeah again x2 on that how is backlash adjusted?
Old 01-19-2006, 01:11 PM
wrightz28's Avatar
washers on the carrier axles, i suck at trying to explain this
Old 01-19-2006, 01:17 PM
....yeah ya do.....j/k.....Is it something that I can get to with the rear still on the car? And in my driveway?
Old 01-19-2006, 01:29 PM
tcfco2005 tcfco2005 is offline
pulling the rear out of our cars is nothing at all after the third or fourth time you can do it in less than 20 min....it takes longer for me to get my car up in there air and on jack stands then it does to take the rear out
1991 RS
305 T.B.I.
700-R4
Old 01-19-2006, 01:33 PM
666_speed's Avatar
Son of Satan
so its something that the rear end will have to come out?
Old 01-19-2006, 04:15 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
You adjust backlash by shimming the ring gear via the differential closer or farther away from the pinion gear. Whinning is not usually the result of too much slack but not enough. Are your gears original or is this the result from someone installing them?. The whinning can also be caused by a bad bearing but if I had to guess and unfortunetly I am left doing that. I would say that your pinion bearing is probably shot due to someone overloading preload on the pinion via a heavy duty impact wrench via the pinion nut.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-19-2006, 04:27 PM
pretty sure the gears are original.
