Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 01-19-2006, 08:49 AM
RICORVAIR RICORVAIR is offline
84 deville map sensor
I get a code 34. Map sensor.
Where does the vacume line go into the passanger compartment.
Trying to locate it has been a treat. Autozone's system had it in the engine bay, passanger side, bolted to the fenderwell. After hours of searching.
My Haynes said it was sometimes under the dash. It is behind the glove box.
The I found no vacume hose connected to it.
Supposedly the hose comes out of the throttle body.
Is this correct? Was thinking of running my own line.
Old 01-19-2006, 04:37 PM
maxwedge maxwedge is offline
A990 racer
Re: 84 deville map sensor
The may be 2 sensors behind the glove box, one is a baro sensor, no hose and the other one is the map of course.
Old 01-19-2006, 07:43 PM
Would it be the same sensor? It looks just like the one Autozone had for it.
If I apply a light suction to it, the engine does change pitch.
Old 01-20-2006, 02:36 PM
HAWG HAWG is offline
they are not the same sensor. If memory serves me correctly the original sensors were round, but I would doubt you still have the original ones on the car. they do look identical, but one does have a vacuum hose routed to it, the other does not.
