Old 01-19-2006, 09:37 AM
cort71 cort71 is offline
Send a message via AIM to cort71
Question loud clunk when turning right
it happens when the car is turned to the right and then back straight
you can feel it in the steering wheel as well as hear it.
im a little worried cuz its getting worse. what am i looking for????
its a 93 pa standard.... you all have helped me a lot in the past. and for that im thankfull
im keeping this car untill i cant afford to fix it anymore.
Old 01-19-2006, 10:34 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: loud clunk when turning right
use the "search" button on this forum. A similar iissue has been covered in detail and may be of interest.
Old 01-19-2006, 12:35 PM
i did that but i guess i used the wrong search term. cuz i came up with nothing
Old 01-19-2006, 05:24 PM
yogi_123rd yogi_123rd is offline
My first guess would be that the sway bar anchor bolts are gone and the sway bar is just flopping around. Very common problem with these cars. The bolt literally rusts off. Your car would "drift" on turns if so. The other possibility is the with the struts - but then they tend to creak.
Old 01-19-2006, 05:28 PM
maxwedge maxwedge is offline
A990 racer
A cheap replacement wheel bearing will do this or the hub to knuckle bolts loose, axle nut loose,.
Old 01-20-2006, 10:36 AM
wrightz28's Avatar
yeah see in the other thread, all these suggestions started flying around, and it ended up being something entirely different, a mount I believe.
Old 02-01-2006, 09:20 PM
thanks all for the sugestions.... but it turned out to be a loose ball joint on the drivers side...got her fixed.... man i had almost forgot how nice she rides when she is in good shape.
