Old 01-18-2006, 11:11 PM
Vlodomyr's Avatar
Vlodomyr Vlodomyr is offline
Send a message via MSN to Vlodomyr
A few Questions
1. Whats the fastest way to get the fuel out of a fuel tank without burning it in the engine, no screw driver holes either.
2. I have an oil leak near my oil pan. I have the suspicion that it is indeed the oil pan, but a few people have told me it may be the seals. I had some tranny work done, and the guy said something about replacing one or both of the seals. Any suggestions on which to replace first?
3. My temperature guage is screwy. I took the dash appart a while back and reset it, and it worked for a little while, and then suddenly went off the meter. Any ideas?
84 z-28 305
Old 01-18-2006, 11:36 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: A few Questions
well the easiest way (takes a while though) i found to get most of the gas out is to disconnect all of the fuel lines and the return line works as a siphon... put a bucket under it and it should take all but about 5 gallons out.... worked for me.... otherwise you could try sticking a long piece of tube down your tank neck and siphoning it that way
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 01-19-2006, 09:25 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: A few Questions
1) Cuda covered
2)Most definatley the front and rear seals, all SBC motors leak over time. If they had the tryanny out, then would have the opportune time. The rear can be done with the trans in (depending on type of seal the motor uses) but it's not fun.
3)You mean during bulb check, the gauge pegs out into the cluster? Also about as common as the oil leak. First make sure your wiring from the sender is ok, sender is the one between cylinders 1 and 3. If that checks out what I've done is pull the dash out, mount a small paper clip and descretely bend it over the top of the guage to act as a stop. A little black sharpe and looks factory and works, you just need to put it right before the needle would get stuck other wise it may off set the guage.
Old 01-19-2006, 04:09 PM
Vlodomyr's Avatar
Re: A few Questions
Thanks alot for all the help guys.
And the tranny guy already replaced the rear seals, when he gave it back to me
Old 01-20-2006, 09:12 AM
wrightz28's Avatar
Re: A few Questions
good man
