Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 01-18-2006, 11:49 PM
Scorpio808 Scorpio808 is offline
86 Bronco Dying out-HELP
I have a 86 Bronco 5.0. I recently change the 2 fuel pump and TPS.After i start it up, it die out after 2 min or so.I try to restart it again but it wont start.I have to waiting about 15 min or so to start back up again but still dies out after 2 min.NEED HELP BADLY
Old 01-20-2006, 04:44 AM
Truck Truck is offline
Re: 86 Bronco Dying out-HELP
Did you check the ignition coil? Those go bad from heat, (that's when you notice them.) so if you can start, and run, but it dies, that's the next place to check.
Otherwise, is there anything about your tank that could be doing it? Do you figure it's full of rust?
Double post...sorry.
