Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-18-2006, 07:39 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Cams and head
I'm looking for a cheap alternative to hks cams. I was the run the 264 intake and 272 exhaust or whatever that would compute to in an alternative cam. Also will a 1g head bolt right up to a 2g block? What other things go along with that swap?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 01-18-2006, 07:43 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Cams and head
I'm pretty sure you gotta have some machining done for the 1g head to bolt up to a 2g block.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-18-2006, 09:19 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Cams and head
Yeah, I dont think its a big deal though. I know what you mean, HKS cams are really expensive. I'm getting Forced Performance cams (or Comp cams, same grind, different name). The FP2's are comparable to 272's with a little less low end and more top end (or so they say) and they are $430 for the pair. You could get a FP1 and FP2 combo, that should be pretty close to the 264/272 combo, but I would just stick with one set.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-19-2006, 02:15 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Re: Cams and head
doesnt the 2g head have better flow? correct em if im wrong
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 01-19-2006, 02:32 PM
Re: Cams and head
I thought the 1g head had better flow and the 2g head was more efficient.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-19-2006, 02:38 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Re: Cams and head
i think its the 1G all the way....
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 01-19-2006, 03:55 PM
blk_srt's Avatar
Re: Cams and head
will a 1g intake manifold fit on a 2g head? still a little in the dark on the whole head fitting
Mods:
Old 01-19-2006, 05:39 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Cams and head
Yes they will fit, some water connections will have to be replaced. I know for a fact the waterneck will have to be replaced with a 1g. Intake manifold will fit as well.
now - 2000 civic
soon - 2002 is300
Old 01-19-2006, 10:38 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Re: Cams and head
I heard 264 on the intake will produce a much better idle compared to a 272 on intake, but that's up to you if you want to sacrifice that for power.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 01-19-2006, 10:41 PM
blk_srt's Avatar
Re: Cams and head
I want to do a 264 on the intake and 272 on the exhaust. I head the same thing. I think I said that, if not sorry. I was really looking for a cheap alternative to the hks versions
Mods:
Old 01-20-2006, 10:10 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Cams and head
Do a set of fp2x cams.
DSM geek
Old 01-27-2006, 08:49 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Cams and head
I ran 264s and 272s on the 2g and I couldn't tell the fuckin difference... Maybe 1 lb/min flow difference, which really falls into the variablity in the measurement anyway. Idle was the same. I highly doubt the combination of the two would be anything magical.
You definitely don't want to use a 2g intake on a 1g head. Ask me how I know... The 1g head will flow ~3lbs/min more than a 2g on a 14/16g sized setup, or about 20-30 hp. Sounds like a deal to me. The 2g head does flow better, but ONLY at low/mid rpm levels. Going to the 1g block and head made the car "feel" a little laggier, even though the 14b was still spooling at the same exact rpm. Just a littleloss in off boost power, which makes sense considering the parts. The price you pay for top end power.
The swap isn't too bad. You'll need a 1g cas and some cooling parts. RRE I believe had the writeup. It's out there somewhere, this has been done and documented a thousand times.
Also, if you are going with the 1g head, and therefore the 1g manifold, you might as well do the 1g TB too. The 2g unit wont fit on the 1g manifold without a little grinding, and why bottleneck the 60mm manifold with a 52mm TB anyway... Just be sure to use the 2g TPS.
To be honest, I'm not sure I would bother with just the 1g head swap. I'd be tempted to wait until doing a full 6 bolt swap. But the choice is yours. I'm probably just getting lazy in my old age
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
