Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 01-18-2006, 06:40 PM   #1
BlazerLT
AF -Advisor
BlazerLT's Avatar
Buying 1998 Neon: Anything I should look out for?
Has 180k kilometers on the chasis, engine has 161,000 and was just dropped in.
Anything I need to look into or look out for other than the headgasket?
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 01-18-2006, 10:09 PM   #2
99 Neon R/T
Re: Buying 1998 Neon: Anything I should look out for?
Timing belt,tensioner and water pump
If it aint broke fix it till it is.
99 Neon R/T is offline   Reply With Quote
Old 01-18-2006, 10:51 PM   #3
BlazerLT
AF -Advisor
BlazerLT's Avatar
Timgin belt is brand new, Iwill keep the tensioner and water pump in mind.
Any reason why these are mentioned.
Old 01-18-2006, 11:03 PM   #4
Ilovemyneon
Send a message via AIM to Ilovemyneon
Is it a single overhead or dual? My car with the automatic 3-speed doesnt get good milage with the DOHC engine. Also the DOHC reccomends premium fuel.
Ilovemyneon is offline   Reply With Quote
Old 01-18-2006, 11:48 PM   #5
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
The timing belt on a neon is a 100,000 mile belt. So while changing it, you might as well as change the tensioner pulley and water pump. If either of those go out, they will take out the timing belt also. The neon has an interference engine, meaning if the timing belt snaps, then your valves will bend 99% of the time. If the HG is a MLS gasket then you should not worry about it too much. Keep up the maintenance on it and it can last you up to 500,000 miles. Do tell if its DOHC, SOHC, ATX, or MTX?
das2123 is offline   Reply With Quote
Old 01-19-2006, 12:23 AM   #6
BlazerLT
AF -Advisor
BlazerLT's Avatar
The engine is the SOHC.
How can I find out what head gasket is on it?
Old 01-19-2006, 07:10 AM   #7
Ilovemyneon
From what I know thereis only one kind. As how many miles are on it. If you can convert that number of kilometers to miles, I can give you a better estimate of what to look for.
Old 01-19-2006, 08:52 AM   #8
das2123
There is more that one kind of HG for the neon. The early 95-98 neons had a crappy gasket that would leak real bad. The late 98-99 neons got the MLS (multi-layer steel) gasket that took care of the problems, as the HG went into production in Sep. 1998. To see if you have the MLS HG look between the 3rd and 4th runners on your intake manifold, there will be a little tab sticking out that indicates MLS. You might have to get a flashlight to see.
Its around 111,000 miles, c'mon google will answer that for you ...
Old 01-19-2006, 11:09 AM   #9
gromittoo
Originally Posted by das2123
There is more that one kind of HG for the neon. The early 95-98 neons had a crappy gasket that would leak real bad. The late 98-99 neons got the MLS (multi-layer steel) gasket that took care of the problems, as the HG went into production in Sep. 1998. ...
My DOHC 98 sport was built near the end of the model year (spring of 99?), and had the bad gasket. If someone can tell me where to look on the car, I get the date.
gromittoo is offline   Reply With Quote
Old 01-19-2006, 01:47 PM   #10
das2123
The build date on the car should be on the sticker on the driver's side door. It should say Date of MFR 11-98, or something to that affect.
Old 01-19-2006, 01:55 PM   #11
gromittoo
I just realized it doesn't matter (i got confused). If the new gasket started in September 98, that implies that all 98's had the bad gasket, and some 99's. My wife bought the 98 in July of 98.
