Old 01-18-2006, 09:55 AM
davyeee davyeee is offline
Angry Fuel Intake
Hello All,
I finished my four year oddessy in putting my CRX HF back together. I drained the gas tank, put in a gallon of gas, and drained it. Then I put in injector cleaner and 6 gallons of frreash gas. Installed a new fuel filter (under the hood, not in the tank.) The problem - as much as I crank on the engine, I do not seem to be getting fuel to the fuel filter. I opened the bleeder bolt which is on the out going side of the fuel filter. Is their a trick to filling the line. Is the fuel fillter acting as a air lock. Do I have a air lock? Should I try to manually fill the fuel bar a fuel filter? Thanks. Dave
Old 01-18-2006, 10:17 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Fuel Intake
Is your main relay clicking when you turn the key? If the main relay doesn't actuate the fuel pump, you won't get fuel pumped through the line to the filter.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 01-19-2006, 08:23 AM
Re: Fuel Intake
I can't even find the main relay. According to the book it is up inder the left side of the driver. I have looked repeatedly and cannot locate it. When I turn the key I do not recall hearing a click.
Old 01-27-2006, 11:52 AM
Rayser34 Rayser34 is offline
Send a message via Yahoo to Rayser34
Re: Fuel Intake
this should help http://techauto.tripod.com/mainrelay.htm
also u have to take that metal plate off under the dash (drivers side) good luck mine was a booger to get out but after resoldering it i have had no fuel issues
Old 01-27-2006, 03:50 PM
Hybrid1990crx's Avatar
Re: Fuel Intake
main relay is under the dash, on the driver side, you can test it by jumping the two terminals on the left and right, dont bother with the ones on the top and bottom, if you can hear your fule pump operating then you know its the main relay. You can also then fix your broken main relay by sodering in a new connection.
Old 01-27-2006, 07:46 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: Fuel Intake
its in there you just have to dig for it...its almost on the same bracket as the hood latch...its on that wall just above it
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
