Old 06-13-2002, 10:18 PM
Accordean Accordean is offline
Talking Retarded first time Honda owner
Howzit enthusiasts? I am a first time Honda owner and I have a really retarded question for you. I drive a 92 Accord LX and have been having some problems with the coolant system. I popped open the hood and noticed that there are two radiator fans!? My instinct tells me that both should be on when the thermostat trips them yet only one runs when I shut the car off. I'm assuming that because the fan fronting the engine is not on (driver side), it causes the block to overheat. A dear (and not so smart) friend told me however that this fan is dedicated to run when the car is running, and the other when it is off. Is he right? Or is he just as retarded as I am? Thanks for your help!
Old 06-13-2002, 10:24 PM
1992civic 1992civic is offline
man freak what he said. i have my fans running all the time... now that its summer time, i need the temperature down to a minimum.. its better for your car. just have your fans set to run at all times. believe me, you'll thank me...
Old 06-14-2002, 08:58 AM
Barwick Barwick is offline
if its anything like my Civic, have you noticed you have 2 "radiators" too? One is the AC condenser and the other is the radiator.
Old 06-14-2002, 09:16 AM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
Your two fans are working properly. One stays on when the engine is on and the other is used when additional cooling is needed. It also stays on a few minutes after shut off to cool your engine down.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 06-14-2002, 09:21 AM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
nah, the fans work just right. mine does the same thing. sometimes after a i stop the engine both of them run depending on hoe hot it is outside
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 06-15-2002, 12:25 AM
Thanks for your help guys.... It wasn't the fans afterall. I figured a Haynes manual would be a wise investment so I went to Checker's, bought one, and found the problem: The hose coming out of the "Fast Idle thermo-valve" cracked and was spewing coolant all over the back of the block. I don't know why I didn't see the crack in the first place. The three inch hose cost $4.00 at Napa, clamps and all. Oops.
Old 06-20-2002, 06:22 AM
VTECseoul VTECseoul is offline
Send a message via AIM to VTECseoul
good job, way to go...you have done more for your car than most 1/2 these ppl. buying the book & DIY, Do It Yourself. Much Respect, Much Respect
2000 Honda Accord LX Satin Silver Sedan
AEM ColdAirIntake
Neuspeed Sport Springs
Nitto 450 225/50
Prime Racing M8 17x7
S15 vs AE86 - 2006 HotWheels Touge
