Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-18-2006, 06:27 AM
thoot12 thoot12 is offline
Exclamation 2000 ls V8 sport Won't start..
2000 ls V8 sport
Engine will turn over but will not start. After a moment of trying I can smell gas, It seems to be turning over fast..Almost like low compression.
70,000 mi plus..
Any ideas?
Trey
Old 01-19-2006, 12:50 PM
34Ford's Avatar
34Ford 34Ford is offline
Re: 2000 ls V8 sport Won't start..
Did you read my thread LS starts but want run? Had the same problem.
Dennis
2003 Mach 1
2008 Expedition King Ranch 4x4
2010 Taurus Limited
Old 01-19-2006, 02:59 PM
Appears to be the battery at this point...
Old 03-03-2006, 03:20 PM
anitsirk anitsirk is offline
my 2002 ls was doing the same thing. wouldnt start and it would smell like gas. i got a new starter, batery, computer system, cut new keys, new fule filter, and some other things that i dont even remember. and it is still doing the same thing.
Old 03-03-2006, 05:54 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
So your LS will crank, but won't start up? Does your car have the V-6 or the V-8?
Have you checked to be sure all vacuum lines are connected and in good shape? Also, make sure the air intake hose is connected and tight.
Do you have a K&N or similar oiled air filter? If so, you may have a contaminated Mass AirFlow (MAF) sensor. If you have a steady hand, some tools, and brake cleaner, you can clean the MAF sensor elements (being VERY careful when doing so) and see if that helps.
Since you mention you can smell fuel, try cranking the engine for a few seconds, then hold the throttle all the way to the floor and crank the engine again. Holding the throttle wide open (Wide Open Throttle - WOT) will turn off the injectors. If the car starts this way, you know that the engine is getting too much fuel. Once the engine starts, slowly release the throttle and see if it will maintain idle and see if the engine will smooth out. You may have an out-of-range coolant temperature sensor or other sensor that is causing the PCM to keep the injectors open too long.
-Rod
Old 03-05-2006, 08:50 AM
beer-b-q's Avatar
beer-b-q beer-b-q is offline
Hey man i dont know if this will help but my car had exact same problem with gas smell and everything. Took it into the shop 3 weeks after looking over everything they found 2 fuel injectors leaking. Replaced injectors started right up.
wait4me
k&n
Old 03-05-2006, 04:09 PM
matt ls matt ls is offline
Mine wouldn't start the one day when it was -20 degrees out, and it was from putting regular fuel in it, started putting premium in it, never had the problem again.
