Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 01-18-2006, 05:27 AM
tclcom tclcom is offline
95 Nissan Primera Remote Key Not work !
I have problem with my remote key in my 95 Nissan Primera 2.0
the key fob not work, only 1 /100 chance ! So I could not turn the red LED off, then can not start the Car !
Does any one could give me some idea ! Is that the problem of fob, need reprogramming ? How ?
Many thanks !!!
Old 01-18-2006, 04:34 PM
nissantech nissantech is offline
Re: 95 Nissan Primera Remote Key Not work !
Hi, Nats 1 system like yours will have to got to the nissan dealer to be re-programed. should not take them more than 5 mins.
I live with fear all week, and at weekends SHE lets me go racing.
Old 01-20-2006, 07:13 AM
You mean NATS 1 could not be re-programmed by the method you mentioned : switch on-off 6 time.... ?
Many Thanks. Nissan Tech
Old 01-21-2006, 08:28 AM
Urgently need some advice !!!
I cannot turn off the NAT 1 (told), so canot drive and take the car to Nissan dealer, then how can they reprogram the remote key ?
Whether I could have any chance to reprogram by myself ? !!!
Old 01-21-2006, 04:54 PM
Hi Tclcom,
the only way is to go to the NISSAN DEALER. you CAN NOT program the fobs yourself.
It is possible to bypass the system. if you feel you have the technical know how, read my other posts. it is not that easy to do.
regards
Old 01-22-2006, 04:56 AM
Great ! I will go to Nissan Dealer and see what they could do !
Thanks you !
Old 01-25-2006, 07:54 AM
The dealer won't like to reprogram it unless I towed the Car to them...
If I could bypass it by disconnect it only ?
Old 01-27-2006, 04:38 PM
To bypass the NATS system is not an easy job. if you feel you have the mechanical skills than i can tell you how to do it. You will need to remove the glovebox and the heater motor to gain exess to the nats immu (control unit). I have a bypass plug made up i can send you pictures so you know which wires you have to link to bypass the nats system. let me know.
Old 01-28-2006, 04:54 AM
I would be glad to receive any help from you !
My email:
[email protected]
Thank you so much !
Old 01-30-2006, 12:45 PM
Hi,
Have emailed pictures to you also.
ok i know for the P10 you have to link as follows.
link pins: 1&2
5&6
7&8
Pins 3&4 are not linked.
hope it helps you out.
regards
Old 02-01-2006, 06:13 AM
Hi, Thanks you so much, however, I havenot received yet;
Would you like try my another email box: [email protected]
Many thanks
Old 12-29-2009, 06:24 PM
rock123 rock123 is offline
help please i have a nissan primera 2.0 1995 p10 nat1
the key fob does not work at all so i can not start the car iam stuck.can the nats immu control unit be bypassed.if so can some one tell me how to do it
thanks in the mean time
