Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-18-2006, 02:20 AM
Foots Foots is offline
Driver Door won't close in cold
It's right at 32 degrees here and now my driver door on my 96 jimmy won't stay shut. Has anyone else had this problem? It happened to me before, but it starting working just a few minutes later. I've always had trouble with the door closing all the way and have had to slam it quite a bit.
Old 01-18-2006, 06:52 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Driver Door won't close in cold
Be more specific... Is it a latch issue? Door pin and bushings?
Old 01-18-2006, 08:05 AM
BlueMonster's Avatar
BlueMonster BlueMonster is offline
Send a message via ICQ to BlueMonster Send a message via MSN to BlueMonster
Sounds like the latch is getting sticky in the cold. It might have some moisture that is freezing when the temperature drops. Spray some WD-40 on the latch, hinges and locks to displace the moisture and then grease it all up to keep the moisture out.
Old 01-19-2006, 10:46 AM
That's pretty much what it was. My father-in-law came by when I was at work and took care of it with the WD-40. Thanks for the advice.
