Old 01-17-2006, 11:30 PM
allstar323 allstar323 is offline
Notchy shifter
I got a short shifter and though the throws are indeed shorter, the shifter has gotten a lot more notchy and is sometimes hard to put into gear. Is there any way that I can alleviate some of it?
Old 01-18-2006, 03:05 AM
justin476 justin476 is offline
Re: Notchy shifter
probably not..did you buy your shifter on ebay? You can also try putting new tranny fluid in, i know that makes the shifts a hell of a lot smoother..but it priobably won't make it totally better.
Old 01-18-2006, 07:39 AM
skotman's Avatar
skotman skotman is offline
Re: Notchy shifter
chaing transmission oil didn't do a damn thing for me, lol. i still grind while trying to go into reverse. first gear is a little notchy sometiems too, but the rest are smooth as can be.
Old 01-18-2006, 10:50 PM
Re: Notchy shifter
Yes the shifter is from ebay. When I installed it, I used those rubber bushings/washers from the stock shifter as well as the original bolt...should I use the bolt and washers that came with the shifter? will it help any?
Old 01-19-2006, 11:15 AM
Smoghog Smoghog is offline
Re: Notchy shifter
I used the washers and bolt from the new shifter. Still notchey. What has happened is we have lost leverage. The old shifter has more leverage because the bottom of the shifter moves less and the top moves more.
I hope you cleaned everything and regreased all.
Also my tranny does the same thing with reverse and first. For reverse I double clutch. And first well it is a fight sometimes. NORMAL...
SH
Old 01-19-2006, 05:28 PM
SiZ's Avatar
SiZ SiZ is offline
Re: Notchy shifter
You're supposed to go into first gear before you go into reverse or you'll likley grind.
Old 01-19-2006, 08:43 PM
88ReX 88ReX is offline
Re: Notchy shifter
I had this same problem when I first installed my short shifter, I didnt think it should be that hard or difficult to shift but it was almost painful. What I did to fix the problem was I took everything apart at the shifter end of the linkage and greased it up really good. I put it back together and this time I didnt tighten it down so friggen tight (this is key, its really easy to overtighten it and make it bind up). After that my shifter moves around with almost no effort at all, like butta.
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 01-19-2006, 11:43 PM
Re: Notchy shifter
hmm I think I might have over tightened it...I can't tell what 16lbs of torque is. (what the bolt is supposed to be torqued to, according to the B&M instructions). I am just afraid of the nut falling off while driving...thus letting the bar fall onto my exhaust, and then having the thing stuck in gear. there's like a millimeter of thread left after the washers and bushing etc. Thanks for the replys.
oh and the thing on grinding into reverse...I thought I read in the manual to prevent grinding, the clutch should be depressed for 5 secs, then shifted into reverse. It does work, but I can't wait 5 secs every single time.
Old 01-20-2006, 07:48 PM
Thumbs up Re: Notchy shifter
If you are worried about the nut falling off then use some locktite on it.
Old 01-21-2006, 10:28 AM
Re: Notchy shifter
Better yet go to the parts store and get a new bolt with a nylock nut.
Piece of mind is worth 3 bucks don't you think!
If you take the time to fix something, do it better than it was.
SH
Old 01-21-2006, 01:14 PM
Re: Notchy shifter
okay, I got underneath my car again today, and loosened the nut a bit. The nut that came with the shifter is a Nylock, so I think I'm set. The shifter moves alot more freely now. (though when I had it tighter, it felt firm and rubbery and my friend said it felt like the s2000's and that I should keep it. but then again it binded sometimes.) Thanks for the help, guys.
