Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-17-2006, 11:17 PM
getfreshco getfreshco is offline
engine swap
will a 350 5.7L vin code "p"Lt1 option engine out of a 95 fit in my 1991 caprice with a 305 already in it. a quick response would be appreciated as the engine is on EBAY
Old 01-17-2006, 11:33 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: engine swap
The engine will bolt into the car, but there are lots of mods that you will have to do to make it work. Take everything in the cooling system except the radiator and including all hoses, and throw them away. You will also have to change the fuel pump as the LT1 requires 55lbs. minimum to run (your TBI requires 12 lbs). There's also the transmission. Your car should have a TH200-4R in it I believe - this will have to be swapped for a TH700-R4/4L60. Your computer and engine wiring harness will also require replacement.
Old 01-18-2006, 06:06 AM
Re: engine swap
thanx for the quick response and information
Old 01-18-2006, 12:52 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: engine swap
yeah there is alot more work involved than most people think
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
