Coming out of lock up
I have 94 Thunderbird with a 3.8 V6 and the trans keeps coming out of lockup. My Check Engine light is not on. Would I still get an error code if I hooked up a code scanner? Also, anyone know what I can do to fix the problem?
Is a 94 Thunderbird ODB2 or ODB1? I am pretty sure that it is ODB2, the connector looks like ODB2. I know ODB2 became standard in 96 but I thought I read somewhere where 94 and 95 Thunderbirds were ODB2. Can anyone verify this for sure? |
Re: Coming out of lock up
Does the overdrive light flash? Your vehicle isnt OBDII, its EEC-IV. There is a connector in the engine compartment, on the right side sort of triangle shaped. This is your DLC. Clipped into the cover with it should be a connector with a single wire. Ground that wih the ignition on and watch the check engine light. It will flash codes. Post what it flashes and I'll see what I can dig up.
No lights on what it so ever. I'll give that a try and post the results. It's pouring rain probably won't be able to get to it until tomorrow.
Its does have ODB2 connector though on the passengers side on the left under the glove box. Unless that is for something else.
I noticed that it does this when the car warms up.
Only V8 94/5 Birds are OBDII. (Well they are, but not really. Kinda like a wanna-be.) Your 3.8L V6 Bird is OBD1. Beginning in 96, all cars regardless of options and engine, became OBDII.
You know what...come over to www.tccoa.com for some more Thunderbird specific help. |
