Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 01-17-2006, 10:23 PM
smokey108842 smokey108842 is offline
Need some tech help!!!!!!!
Hi I have a 97 Neon sport 2.0 dohc. I believe the head gasket blew because i was refilling radiator fluid at least 3 times a day and then it just quit running. It has by far been my favorite car and I don't want to get rid of it and I like doing everything myself. Would I just have to change the head gasket or is something else wrong too? What else should I do while I have to motor apart?
Old 01-18-2006, 07:50 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Need some tech help!!!!!!!
If you have a blown HG, then you should see oil in your coolant or coolant in your oil. If you were putting in that much coolant, then you may have had a bad coolant leak. Check and inspect all your hoses. Did your temp gauge ever hit the H mark? You may have overheated your engine.
