Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-17-2006, 09:40 PM
96neonwidriver's Avatar
96neonwidriver 96neonwidriver is offline
Send a message via AIM to 96neonwidriver Send a message via Yahoo to 96neonwidriver
Angry no compression no spark
so i have a best friend with a 1990 plymouth laser 1st gen. he just had a motor swap done to it and ever since it has run like crap. it has been shooting white exhaust, stalling when he pushes the throttle, a sticky throttle cable, and a leaking steering pump. just last night his car stalled and finally stop. now it wont start at all. ahhhhhhhhhhhhhhhhhhh whats wrong. i think it might be a bent valve or a hole in the inner wall. whats the opinion out there.
Old 01-17-2006, 10:03 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: no compression no spark
My guess is head gasket. White smoke is coolant being burned. Do some tests and find out, see if the plugs are firing, see if theres compression and see if the injectors are pulsing. Test those and you will find your problem. btw is it a turbo or na?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 01-17-2006, 10:08 PM
yeah its a nt hes wants to make it turbo but we need to get it running first. we did check the spark and there isnt any spark soo thats on prob. the wire to the injectors was snapped from the guy that dropped the "new" engine in so we did have to fix that. could that cause something that big???
Old 01-17-2006, 10:09 PM
by the way nice setup. which rims are those?
Old 01-17-2006, 10:12 PM
blk_srt's Avatar
Have you checked to see if the injectors were pulsing after you fixed the wire? The spark could be bad plugs bad wires or a bad coil pack. my rims are exel dl-46
Mods:
Old 01-17-2006, 10:15 PM
just replaced plugs last night before the problems and after the wire was fixed it was running in the shop for about 30 minutes. ie sparks were bosch +4
last night we did an oil change, sparks, and fixed the wire
Old 01-17-2006, 10:17 PM
blk_srt's Avatar
I'm not a big fan of bosch plugs. If I was you when it gets running again throw some ngks on there. Have you checked the plug wires at all?
Mods:
Old 01-17-2006, 10:19 PM
yeah they were replaced about a month ago on the old engine and were brought over to the "new' engine but they are only the stock
Old 01-17-2006, 10:24 PM
blk_srt's Avatar
Well then IIRC that leaves like 3 things that would cause no spark, the coil pack, transistor pack, or ecu. none of which are cheap. Test and see if you can pin point it before you spend a whole lot of money where you dont need to
Mods:
Old 01-17-2006, 10:26 PM
oh yeah heres an update.... he just called me and told me upon inspection he found a three inch crack on the manifold 2nd pipe from left
Old 01-17-2006, 10:28 PM
lol very true thanx man we will be looking at it tommorow and we will check those.
Old 01-17-2006, 10:29 PM
blk_srt's Avatar
Intake manifold?
Mods:
Old 01-17-2006, 10:34 PM
yeah sorry getting late personally this mechanic that put it together definetly did things pretty shady i dunno
im sorry its the pipes right in front thats the exhaust right? again its late im not firing on all 4
Old 01-17-2006, 10:40 PM
blk_srt's Avatar
lol yeah, its oppisite from a neon
Mods:
