Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 01-17-2006, 08:59 PM
Crx_baybee Crx_baybee is offline
2nd Cylinder In Mi 87 Crx Full Of Oil
Hey can anyone help me with this problem, the 2nd cylinder im my crx is full of oil and it had been runnin fine for ages before today, now it wont start. is there anyway i can fix this or is the engine completly shot?
ta, ciara
Old 02-01-2006, 10:00 AM
flyviper69 flyviper69 is offline
Re: 2nd Cylinder In Mi 87 Crx Full Of Oil
my guess is your valve train is letting oil into your cylinder, i would cheack out the head.
Old 02-01-2006, 10:21 AM
5150crx's Avatar
5150crx 5150crx is offline
Send a message via AIM to 5150crx Send a message via Yahoo to 5150crx
either a valve stem seal(s) just desided to dissapear completely(possible) or your piston rings ate it....if the hole is really really full of oil....you could have potentialy hydro locked the motor(and bent a rod). pull the spark plugs out...disconect the coil...and crank the starter...try to get the oil out of the hole....if the oil keeps coming....rebuild or replace the motor....if you are able to get the oil out...run a leak down test on the motor...if the leak down is not bad...start pulling the head..
Old 02-02-2006, 11:32 PM
thanx for the help , i in the middle of replacing the engine, Ciara
