Old 01-17-2006, 08:05 PM
deisel_35 deisel_35 is offline
91 chev 350 intake issues
have an older style block with centre bolt heads. replacing the intake and curious why the rear water port is closed off in newer model 87 and up and not prior to 87. do I need to close off or leave open with a 84 block and 91 style heads?
Old 01-17-2006, 08:15 PM
malletslinger's Avatar
malletslinger malletslinger is offline
Re: 91 chev 350 intake issues
are you refering to the hose lines that lead to the heater-core?
Old 01-17-2006, 08:21 PM
no referring to the intake manifold gaskets
Old 01-17-2006, 08:34 PM
Then what do you mean by "rear water port"?
Old 01-17-2006, 09:34 PM
TEXAS-HOTROD TEXAS-HOTROD is offline
1987? Or do you mean 1997?
The early intakes that have a rear port heater supply fitting have open gaskets. Later engines that have the heater supply in the front coolant crossover have the rear water port block-off gaskets.
The intakes also have internal water jacketing to cool the e.g.r. passage.
