Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-17-2006, 04:50 PM
pacman99 pacman99 is offline
2000 GS Power Window/Wiper slowdown
Hi,
This has been happening for a while now. When it's cold outside [not that cold, maybe -10C?] and I'm driving a bit in rush hour, my wipers and power windows start moving very slowly. It's as if I have no battery left. The battery itself is brand-new and was tested to make sure there's no bad cells etc.
Once I start driving though, it gets better. I do have heating on at the same time (front and rear windshield). I've tried both medium heat and full heat on level "2". CD Player is on at the same time. Also tried turning that off for a bit but not too long.
Am I running too many things and putting too much strain on my battery?
Thanks~
Old 01-17-2006, 05:42 PM
WReX WReX is offline
Re: 2000 GS Power Window/Wiper slowdown
your battery should be able to handle that many things at once, that might be a sign of an alternator going bad
have a shop check the charging system and the components
26 PSI anyone?
Old 01-20-2006, 01:12 PM
gnushit's Avatar
gnushit gnushit is offline
Send a message via AIM to gnushit Send a message via Yahoo to gnushit
sounds like the alt also
"women are like guitars, they all come with strings attached" - king of the hill
Old 01-20-2006, 06:59 PM
yea i had a mechanic check it out and he also says it's the alternator. But he said that there's no need to change it now. Like the problem will still be there but said to change it when my car starts complaining about it (a light comes up complaining about the alternator).
I'm not sure if this is a good idea. Should I wait to get it fixed because it's just a bit annoying. It's not really preventing my car from starting up yet or from pulling down the windows etc.
also, do 97 integra parts fit 2000 ones?
Old 01-20-2006, 08:27 PM
gnushit's Avatar
you'll need to change it sooner or later, might as well do it now. yes, a 97 alt will fit a 00
Old 01-20-2006, 11:09 PM
well i had a problem with my brakes taking in air so I wanted to fix that first and then worry about the alternator later. As long as there's no damage possible by delaying this, I might just put it off for a month or so.
Old 02-14-2006, 07:33 PM
i went to another mechanic about the same problem. The battery is charging at approx 14.2-14.3V so the alternator seems to be fine (this is with everything running). I've been told it could be the electrical wires freezing??? or the window track being bad and needing replacement.
Any comments? I don't want to replace the alternator and find out that it was fine heh.
Old 02-14-2006, 08:12 PM
you might just need to lube up the tracks on the window regulator and maybe see if you can to the lube points on the windshield wipers
it could just be slow due to lack of lubrication or maybe just the motors going bad
26 PSI anyone?
Old 02-16-2006, 12:11 AM
tainted_demon tainted_demon is offline
The voltage output is 14V, but what's the voltage output under load? If your getting 14V unloaded but 8V loaded then something is wrong. If an electrical wire freezes (or just gets cold) it actually improves conductivity, which would result in better performance (not by much though). Look into the window track, the easiest thing to do could probably just pull off the door panneling and rool the window up and down and look for a jam or something sideways.
My Ride: '86 Cressida, InLine 6 Cylinder (5M-GE), 175,000 km ... I want an b18c1...
Old 02-16-2006, 05:29 PM
i'm not sure about unloaded
what I have noticed is that the window gets slower in the middle so it could just be a problem in the track. Thanks I'll have a look at it~
