Old 01-17-2006, 04:04 PM
onehate02 onehate02 is offline
Send a message via AIM to onehate02
body lift questions
I am considering a 3" body lift for my '04 ext. cab because it sits pretty low considering its not the 4x4. I still have the stock 245 tires and am about to purchase bigger tires. Would 285's fit perfect with a 3in body lift? Could I go bigger? Where can I take my car to install the body lift and how much will it cost? Also, do only the 4x4's have t-bars because i want to level my front end. Thanks for the help guys.
Old 01-17-2006, 06:58 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Re: body lift questions
Do a suspension lift, you'll thank me later.
*Under Construction - New sig to debut*
Old 01-17-2006, 07:59 PM
I wish I had the money, but I don't... which is why I'm interested in a simple body lift.
Old 01-18-2006, 12:44 AM
kenwood guy's Avatar
kenwood guy kenwood guy is offline
Send a message via Yahoo to kenwood guy
how much of a difference between the two???
Simon R
2001 Silverado W/T 4.3
124,000
Old 01-18-2006, 05:20 AM
bigbadram51 bigbadram51 is offline
Get the suspension lift if you can swing it in any way. If you cannot possibly do it. Do the body lift right. make sure you get the stuff to hide the body lift. so you cant see the space between the frame and body. That looks so friggin bad. Also get the bumper relocation hardware. Once you do this you would probably be better off with the suspension
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
3" PA Body Lift
Covermaster Top
Old 01-18-2006, 08:09 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I completely 100% concur with this. Body lifts look like crap ...
But to answer your question. Yes 285's will fit. I have 285's now and I have no lift at all.
If you would like, I'm sure 305/70's will fit witha 3" body lift, 315's might even fit I'm not sure. It all depends on what wheels your using and the backspacing whether or not they will rub.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 01-19-2006, 08:46 AM
06Z71 06Z71 is offline
Lightbulb Re: body lift questions
The 315's will fit with body lift but they will rub a little when going in reverse and turning sharp to your left. you might have to cut off a 1/4 inch of the black plastic inside your fender well on the driver side only.
Old 01-23-2006, 05:55 PM
ok thanks for the help. what is the bumper relocation thing for?
2004 Silverado ext. cab 4.3L
Pirelli Scorpian A/T 275's
Magnaflow straight-through muffler (dumped)
K&N FIPK
Custom sound system (alpine/infinity/monster)
Billet Grille inserts & bowtie
Xenon blue bulbs (high/low/drl)
Limo Tint all around
Gaylords X-2000 tonneau
Rhino bed liner
Code Alarm keyless entry system
Custom PA system (dual speakers)
A1 Power Window mod
Center console swap
Old 01-23-2006, 06:27 PM
Well, if you do the body lift, the body will move up 3", but the bumper will remain attached to the frame and you will have this gap, that looks horrible. The bumper relocation brackets just move the bumper up so it looks stock
3" PA Body Lift
Covermaster Top
