Old 01-17-2006, 03:31 PM
rnorth rnorth is offline
blower / fan motor
have an 02 grand prix. fan does not work on positions 1 2 or 3, works fine on the others. I've done some searching and still have some ????. how do i tell if the motor relay is gone. where are the relays located and how much of a PIA is it to get to????
Old 01-17-2006, 03:45 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: blower / fan motor
If you have manual HVAC it is a blower motor resistor which also has the hi-speed relay. If it's an auto. digital climate control system it is called a blower motor control module. Both are located in the lower part of the HVAC assembly by the blower motor (passenger side). Blower motor must be removed to remove the BMR or module.
Search for "blower motor resistor" because we have a lot of old posts to include R&R procedure with pics.
Timeslip 08/12/06
AF Community Guidelines
Old 01-18-2006, 07:18 AM
thanks for the help.
Old 01-18-2006, 08:19 AM
BNaylor's Avatar
You are welcome. Just in case here's a good link with R&R procedure with pics. Good luck!
http://www.clubgp.com/newforum/tm.as...4160907&cookie
Timeslip 08/12/06
