Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 01-17-2006, 02:58 PM
kgriggs75 kgriggs75 is offline
88,88 stalling when hot
1988 delta 88 3.8 vin c 115k. previous parts replaced by me within the last two months,altenator, egr, fuel filter, battery.
After the car has run for 20 to 30 minuts it shuts off, no sputter just off. you will have to let it sit for a couple of minuts before it ill run again, but will shut down again with in a minute or two. the ecm is storing no codes there "appereas" to be good fuel pressure.
Old 01-17-2006, 03:36 PM
maxwedge maxwedge is offline
A990 racer
Re: 88,88 stalling when hot
Does it have spark when you attempt to restart and /or fuel pressure at the rail, this is basic preliminary diagnostics.
Old 01-17-2006, 04:07 PM
I still have great fuel pressure but no spark
Old 01-17-2006, 06:37 PM
A990 racer
Ok now you need to check for injector pulse also, if none you can be pretty confident the crank sensor or the wiring to the icm from the sensor is bad, a scan will tell you if there are cranking rpms, if none you are back to the ckps or wiring.
Old 01-17-2006, 09:59 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
If I recall right, the ICM when it goes bad will malfunction when an engine heats up to operating temperature. You could always remove it and have it tested at autozone or o'riely for free...
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 01-18-2006, 11:39 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Faulty Crank Position Sensor. If you replace it the stalling problem should go away.
Old 01-18-2006, 04:04 PM
replaced the crank sensor. hasent stalled yet.
Old 01-19-2006, 08:47 AM
well that problem is fixed but now its showes a code 41. man im about sick of this thing.
Old 01-19-2006, 12:59 PM
Pontiac Guy
Code 41 is the crank position sensor. Clear the code and see if it comes back on. May be on just because it reads a new sensor or registered the code when the sensor was unplugged. Just remove the battery terminal for a few minutes, this should take care of the code.
