Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 01-17-2006, 11:32 AM
xxervio xxervio is offline
Send a message via AIM to xxervio Send a message via MSN to xxervio
Car running cold...
I am pretty sure it's the thermostat i need to replace. Just want to get opinions. Sometimes the car is taking a while for the car to warm up, also when i drive it the temp guage drops down towards the cold side and then raises back up. I went over to my parents and had the car sitting idle for a bit and the temp guage was about 1/4 away from the C side. Also Where exactly is the thermostat located so i can change it out?
2002 zx2
Old 01-17-2006, 05:12 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Car running cold...
if the thermostat was bad the car would run hot
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 01-17-2006, 05:26 PM
RahX RahX is offline
not necessarily, the thermostat can be reacting slowly and not closing all the way or it could be broken and not letting the coolant warm up before letting it cycle.
Old 01-18-2006, 09:42 PM
pre98zetec's Avatar
even if it was open all the time why would it be running cold? (should be running normal)
if it was stuck closed (the car would run hot) because there no coolant circulating
my temp guage always read cool even if it was hot, wasnt the thermostat it was the coolant temp. censor
-Josh-
Old 01-18-2006, 11:47 PM
if youve ever run a vehicle without a thermostat you would know that the thing will never warm up and it gets hot spots. the thermostat closes when the coolant temp gets to a certain temp and opens when the temp is high enough. so one that is stuck open or sometimes not closing would keep the engine from warming up. however, a bad CTS could still be the problem but a thermostat is cheap and fairly easy to replace. how is the heat in the car?
Old 01-22-2006, 12:39 PM
the heat in my car goes along with the temp guage. When the temp gauge needle falls to the cold side the air in my car even on hot goes cooled. when the needle goes back up so does the heat.
Anyone tell me where the thermostat is located trying to chnge this out today.
thank you
Old 02-12-2006, 10:18 AM
Timtickle Timtickle is offline
Replace the temostatt with a 195 temp from any place other then autozone. If you follow the top radiator hose back to the plastic housing with 3 bolts securing it. Its under the housing.
Also, anyone that reads this site, dont listen to sk8ter_in_ny, hes an idiot.
Old 02-12-2006, 12:36 PM
pre98zetec's Avatar
-Josh-
Old 02-12-2006, 12:43 PM
SupaMan89T's Avatar
SupaMan89T SupaMan89T is offline
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
uh if the thermostat is stuck closed the car will run hot not cold
WHICH IS WHY LOTS OF HOT RODDERS IN FLORIDA RUN NO THERMOSTAT BECAUSE ITS HOT AS HELL ANYWAYS.
http://auto.howstuffworks.com/cooling-system2.htm
here learn something before you call people idiots.
Project Lexus Revive
