Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 01-17-2006, 02:50 AM
Deadboy's Avatar
Deadboy Deadboy is offline
Send a message via MSN to Deadboy
D16A1 or ZC?
OK how do you find out if its a ZC or a D16A1 Does it say on the block D16A1 or does it say ZC something?......its said that its from a integra but what if it came from a 1gen crx.....not been swaped...car came from germany 1 owner and then ended up here and died when got hit by a truck from behind....so how do i know what engine do i have?.....it has the polts in side and is a brown top
i found on the internet :
1G ZC "Brown Top" D16A3
Engine ID: ZC
CC: 1590
Hp: 135@
TQ: 112@
Bore: 75mm
Stroke: 90mm
Compression:
Fuel System: PGM-FI
Ignition System: Vacuum Advance
Notes: Valve Cover Bolts are in the middle of the valve cover, NOT USDM LEGAL
Could it be this?
Old 01-18-2006, 03:16 AM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: D16A1 or ZC?
well i'm no expert on the topic but from what i remember the EDM CRX motor is a step down from the ZC by like 5 or 10 hp. it's not a true ZC as it's an EDM and not a JDM motor but effectively the same thing
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 01-18-2006, 09:06 AM
Deadboy's Avatar
Re: D16A1 or ZC?
I read that if it does not say ZC its not a ZC but it says ZC1-120....... on the block.......best way to know is dyno it
If it not a ZC then why the hell do they write ZC on blocks that are not?
One other thing if i was to use a 89 ZC wireing would it worke with the 86-87 motor? i knoe that the 89 is elect. timing and the 86-87 is vac. timing....could that be a problem?........and would the ECU work with the older engine?
Old 01-20-2006, 12:11 AM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: D16A1 or ZC?
Sounds like you've got a ZC to me! The ZC1 was the first ZC and was produced from '85-'87.
There will be small issues with the swap you have in mind. The distributor bolts are in a different configuration, so if you want to use the EA distributor on your Browntop, you'll need the distributor cam cap from an '88-'89 Integra. This way, at least you'll be able to have the dizzy hanging on by one bolt.
The ECU's are also different, you'll need to use the '88-'89 ECU in order to control the EA dizzy. Because of this the wiring is different and is the biggest headache with this swap (I know because I wired my car for an electronic advance distributor).
This is all assuming that you're starting with a car that is wired for a VA distributor.
Old 01-20-2006, 09:47 AM
Deadboy's Avatar
Re: D16A1 or ZC?
Hmm thx for the info.....look like ill be going to the junkyard again
