Old 01-16-2006, 10:34 PM
coltabsh coltabsh is offline
Unhappy 91 s10 brake problems
my problem is when i start, The brakes will not work also runs kind of rough untill it warms up about 2 min. After that they will work but know its taking longer and longer for the brakes to work
thanks for any help
91 s10 blazer 4x4 4.3L TBI
Old 01-17-2006, 12:12 AM
OverBoardProject OverBoardProject is offline
Banned
Re: 91 s10 brake problems
Sounds like a vaccum leak to me that seals it's self a little when it's warm.
You'll have to spray some WD40 on the vaccum hoses while it's running (cold) and when it suddenly revs up you'll know that you sprayed the leak
My guess is that it's the somewhere along the thick hose going to the brake booster.
Old 01-17-2006, 09:51 AM
91gsx 91gsx is offline
Also sounds as if it mite be flooding, ( or getting to much fuel ) then as it warms up starts to clear out, or now burning the unused fuel, you might want to check your sensors and see if there is a problem with any that involve cold start and fuel, which I believe there is, maybe somewhere near the themostat housing.
Old 01-17-2006, 09:30 PM
joshmitch05 joshmitch05 is offline
Flooding wouldn't cause the brakes to function improperly. As already stated, sounds like a vacuum leak around your brake booster (big black cylinder on the firewall, driver side).
Old 01-29-2006, 08:17 PM
bigd7315 bigd7315 is offline
Send a message via Yahoo to bigd7315
also if no vaccum leaks listen for a hissing sound when depressing the brake pedal the booster might be going out on ya
Old 01-30-2006, 12:14 AM
RahX RahX is offline
i agree, sounds like a brake booster going out.
