Old 01-16-2006, 09:29 PM
DaGrease's Avatar
DaGrease DaGrease is offline
Unhappy Service Engine Soon Light of DOOM
I own a 2.8L 89 firebird and recently the SES light goes on and there is a loss of power (i have to be in 5th to get it up to 50 km/h. The weird thing is that it goes off and on randomly and whenever it is off it runs normally. I took it to a local shop to run it on the computer and they said they couldn't get it to set off.
Any suggestions would be greatly appreciated...
Oh and i want to get it painted....Any suggestions would be great
Old 01-16-2006, 09:37 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Service Engine Soon Light of DOOM
might be the smog pump, most likely.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 01-16-2006, 10:06 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
What do you mean by set off?. Do you mean they couldn't read it or couldn't get it to flash codes?. The process to reading codes on OBD 1 early systems is quite simple.
Turn ignition switch to OFF position
Locate Data Link Connector (DLC), see image below.
Jumper the A&B terminals(a paper clip or a jumper wire work ok)
Turn Ignition switch to ON position.
Count the flashes on the "CHECK ENGINE" or "SERVICE ENGINE" light.
FLASH, pause, FLASH, FLASH = code 12
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-17-2006, 06:38 PM
DaGrease's Avatar
Hi FormulaLT1,
It blinked once, paused, then blinked twice, then repeated itself. So you were right, it is code 12...what does that mean?
It's a good thing they didn't charge me anything
Thanks
Old 01-17-2006, 06:48 PM
FormulaLT1's Avatar
Fight the powwa!!!
Code twelve is just a check code that means the ECM is functioning properly. Did it flash any code after it flashed code 12 three times?. If so, whatever number that was. That is the code you had in the computers memory.
Old 01-17-2006, 07:00 PM
DaGrease's Avatar
It read Code 42
Old 01-17-2006, 07:05 PM
DaGrease's Avatar
A website said it's a Bypass or EST problem
http://iroczone.com/specs/ECMTroubleFBody.htm
Old 01-17-2006, 07:10 PM
FormulaLT1's Avatar
Fight the powwa!!!
Its a ignition module code. You need to check the connection on that and then most likely replace it.
Old 01-17-2006, 07:12 PM
DaGrease's Avatar
Talking Re: Service Engine Soon Light of DOOM
Thanks for all your help Formula
Old 01-17-2006, 07:13 PM
FormulaLT1's Avatar
Fight the powwa!!!
No problem. Good luck
John
Old 01-20-2006, 07:58 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
i need help... i just got the SES light this morning..and i did the jumper, i saw the 1:2, 1:2, 1:2 and then it flashes 3:6 ?!!? is this a special case? whats up with this.. after it flashes 3:6 three times, it goes back to 1:2, 3 times, then back to 36...whats an error 36?!?! is my car screwing with me?!
its a 1988 5.7L TPI WS6 formula..
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 01-20-2006, 08:25 PM
FormulaLT1's Avatar
Fight the powwa!!!
Thats a MAF code. Check the connections to the MAF and if those check out. Then your going to check the MAF itself.
Old 01-20-2006, 08:37 PM
ohh, thanks! i have a spare MAF..it came w. the car so maybe ill try swap it and see..
Car:
285's in the back
all else = STOCK.
Old 01-21-2006, 11:56 PM
hey LT1! thanks i finally changed the MAF and the code wouldnt go away..so i was pretty bummed cuz i thought i had to buy another one...
after tonight tho, it worked! wooo.
Car:
285's in the back
all else = STOCK.
Old 01-22-2006, 12:33 AM
FormulaLT1's Avatar
Fight the powwa!!!
a code is stored in the ecm memory til the ECM is reset , either via disconneting the battery for 10 minutes or via a scan tool. Glad it worked though.
