Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-16-2006, 07:29 PM
truc0011 truc0011 is offline
Removal of Oil Pump Drive
I am in the process of replacing my lower intake and was told by the dealer I should replace the oil pump drive o-ring. I have removed the retainer bolt and clamp but the oil pump drive doesn't pull out very easy. What does everyone do to remove it? Pry on it with a screw driver or do you pull on it from the top??
Thanks for the info!
Old 01-16-2006, 10:18 PM
cdru's Avatar
cdru cdru is offline
Re: Removal of Oil Pump Drive
Pull on it from the top. The first time I tried to get mine off, I had a heck of a time getting it. What I ended up doing was getting a pair of sharp channel lock pliers that got a good grip on the top. I then used a pry bar in a gap between the pliers and the top of the shaft to pop it up.
Don't worry about screwing up the top of the cap; only worry about screwing up the surface where the cap meets the block. This means try to avoid forcing something between the two and prying up on it.
Vinyl adds horsepower, right?
Old 01-17-2006, 06:54 PM
gkindub gkindub is offline
Why replace the oil pump drive o-ring??? CDRU, you seem to have done alot of work on your 98 or 99 Montana--why or have you replaced the above mentioned o-ring??
Old 01-17-2006, 08:19 PM
Glen_T Glen_T is offline
Mind if I make a comment? I seem to recall that this 3.4L is an offshoot of the older 3.1L engine that used to have a distributor coming out the top of the engine. The oil pump drive is also driven off the camshaft in the same location, and I believe on that engine, the bottom of the distributor shaft had a recess in it that the long oil pump shaft plugged into (coming up from the pan). When they went distributorless, they put a plug in there that was basically just the bottom end of the distributor, with an o-ring at the top. On my old 1990 3.1L, the o-ring would begin to leak slightly at around 70k miles. Not sure if it was the wrong material choice by GM, but I suspect it gets pretty hot there and they may have a hard time keeping any polymer from drying out. I seem to recall my dealer didn't even charge me for the o-ring because it was such a common problem.
If the 3.4L is an offshoot from the 3.1L, then the o-ring may still leak on occasion....Glen
Old 01-17-2006, 08:21 PM
Because it is the perfect time too. If it was to fail it would be alot harder to replace with the intake on the vehicle.
Old 01-18-2006, 08:20 AM
cdru's Avatar
What Glen and truc0011 posted are exactly the reason. GM originally used a o-ring that wasn't designed well enough for the extreme temps and pressure it is subject to right there. As a result, the o-ring hardens and eventually leaks oil since it is subject to direct full oil pressure.
You will never have a easier time getting to it then when the lower intake manifold is off, so it's one of those things that you replace just on general principal. It's a $2 part that can save you a lot of money/hassle down the road if you had to fix it later. Some people also use the paper gasket the older distributor engines used as a "backup" gasket although I don't think it's really necessary.
There are also 2 other o-rings I suggest replacing. One is where the heater core pipe plugs in near the thermostat housing, and the other is where the bypass pipe plugs in near the water pump. Checking/replacing the clamps and hoses back in the heater core plumbing also will never be easier. Trust me, you don't want to have to replace a hose or clamp back there with the manifold on. There is no room. The 02 sensor also is right there...
