Old 01-16-2006, 12:56 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
tranny mount
ok, so i am going to replace the tranny mount, how do i do this? it is on my 92 r.s camaro 305 auto. do i need and special tools?
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 01-16-2006, 03:45 PM
tcfco2005 tcfco2005 is offline
Re: tranny mount
nope just a jack and a socket...dont remember what size....just put the jack on th tranny and jack it up just enough so its off of the mount then you take the mount out and reverse the process to put it back in....on my car i ended up taking the whole crossmember off which wasnt bad at all....i dont know if you will need to do that or not.but its pretty simple...
1991 RS
305 T.B.I.
700-R4
Old 01-16-2006, 06:12 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: tranny mount
Yes, its pretty simple and sometimes if the bolts to the tranny are on there real good, like mine where you do need to remove the crossmember but in most cases you can get them off with a standard open end wrench.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-16-2006, 06:21 PM
97cavalier's Avatar
Re: tranny mount
ya, it is kinda rusty under there, so i will soak the bolts and see what happens, i am going to put a polyurithin mount on there. And i had one more question, when you replace it, is it only the rubber insert? or is it the hole metal peice?
Old 01-16-2006, 11:11 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: tranny mount
whole piece between the tranny and the crossmember. dont forget to put a piece of wood across the tranny pan before you put the jack under it.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 01-17-2006, 12:12 PM
97cavalier's Avatar
Re: tranny mount
ya i was wondering about the pan how i was going to do it, thanx for the tip!!
