98 supercharger oil change
Hello,
I found the part number for the super charger oil. Anyone have any instructions on how to change it and how much to add? Thanks for the help, Also what would happen if I replaced the OEM oil with Full synth? |
Re: 98 supercharger oil change
go to walmart and buy a cheap turkey baster with a small nozzle that can fit inside the opening in the SC. After youve siphoned the old fluid out, just pour the new in. It'll take at least one bottle and part of the second. just fill up until you see the fluid reach the top of the threads. Good Luck!
Thanks for the instructions. Now what If I dont use the GM OEM oil? What if I use Mobile One Full Synth? What yould the pros or cons be?
Is it a different grade of oil? |
I'm not sure of the viscosity of the SC oil, so I can't direct you there, but I would strongly reccommend using the oem oil. I'd be willing to bet that regular synthetic motor oil is a little different than sc oil. SC oil looks like power steering fluid in color. a really clear amber color.
I checked my level the other night and it looked a little low. About 1/2" below the hole. I am thinking of changing it out also, with almost 120k miles on mine. Let me know what you find out...
~Dave~ '08 Chevy HHR SS, Victory Red, 5 spd. 2.0L Turbo, 52K mi. '98 Buick Riviera, Black, 3.8L Super-Charged, 228K mi. '98 Chevy Tahoe LT, 5.7 Vortec, Black 241K mi. '70 Pontiac Firebird Formula 400, 4spd 200k+ mi., in process restoration '10 Dodge Grand Caravan SE, 11K mi. |
spruce: the dealer has it and you definately need to change it at those high miles. I'm not sure if it's indeed relabeled mobil as you said, but use the Gm stuff. I've heard several opinions on goodwrench oils. Some say its mobil, others say pennzoil and some say GM buys whoever sells it to them the cheapest. GM dealers were selling Shell brand ATF a while back when i was looking for trans fluid. I finally found the goodwrench stuff though
The supercharger is only $3.00 a tube. You will need two tubes. Easy job. I got mine at the dealer.
Chris, 1993 Buick Skylark 3.3 122,000 Miles 1998 Buick Riviera 3.8 SC 57,000 Miles 2000 Olds Bravada 4.3 70,000 Miles |
Thanks guys, I'll definitely do the SC oil change. Previous owner said he did everything by the book at the dealer service, but you never really know without any receipts!
True to that!
Where is the opening to add the new oil in SC, I have a 97 riviera and want to change the oil. I found the oil OEM oil for this for $12 a bottle. Please let me know
With the hood open, locate the SC on the left side of the intake manifold. There is a small black plug on the front of the unit that can be removed with an allen wrench. It is an allen type plug, not a torx. you risk damaging the plug by using a torx socket.
Thankyou for the help Tman
Another question I have is where
to get a service manual for my riviera |
Anthony, good to see you posting again! We have missed your regular participation in the Buick forums! In order to keep things consistant here, I will attach the following.
Posting in closed or outdated threads ![]()
Knowledge can be communicated, but not wisdom! ![]() ![]() Last edited by HotZ28; 12-10-2006 at 08:19 PM. |
