Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 01-16-2006, 09:55 AM
Plusdaddy Plusdaddy is offline
vg30et swap question
hey i am going to swap my motor in my 86 z its currently n/a i want to swap it with a vg30et...what is evertyhitng i have to do to do the swap..some one said..the turbo cross member..can some please help me with a list i will need to do it
Old 01-16-2006, 11:47 AM
stephenp stephenp is offline
Send a message via AIM to stephenp
Re: vg30et swap question
well the basics for starters as in injectors exhaust manifold and the turbo itself
from there you need something for the ignition to keep proper timing under boost i hear the msd boost timing master is a good choice
after that you need someway to controll the fuel for the basics a bigger inj. but you may want to lower the stock pressure at idle and return to normal pressure under throttle you can buty a fmu (fuel managment unit off ebay for under 100)
if thats out of your range of mechanics that you may wan t to jsut get a front clip of a turbo and if not try and get a wirin diagram and the ecu
most people will tell you that you should just get the turbo version its cheaper asnd easier
also if you keep stock na motor and pistons do not exceed the stock setting if you do no more than 8 psi to much heat and detonation and poof blown head gasket
good luck
Old 01-16-2006, 12:22 PM
nah i am going to get a whole new motor..jdm vg30et it is the turbo one
Old 01-16-2006, 02:28 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
ECU
Harness
Turbo Tranny
Intercooler Piping
etc.
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 01-16-2006, 04:05 PM
if its stock there is no intercooler but yeah the rest is right
and an intercooler is highly recomended over 8 psi
and ac tually according to z31 the na tranny is a stronger model
allthough i have to disagree only because nissan put the tranny in there because it was stronger
bvut there are people with 240s and the same tranny with over 400hp blah blah blah
new clutch is recomended
good luck
Old 01-16-2006, 09:00 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
There's no such thing as a "JDM" vg30et... they had RB25det engines (I think).... while you're doing all of this, see if you can get your hands on a 87+ turbo tranny, and an LSD rear-end.
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 01-16-2006, 09:18 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
*sigh*
ok guys listen up...
if you've got the engine/turbo/all that stuff all you should need is the turbo crossmember, ecu, (injectors, sensors etc if they didn't come on the engine) and most likely a stronger clutch depending on how long you've had yours for..
yes, there is such thing as a vg30et, it came in the turbo z31's that were made in japan... durr
1via pay attention to the missing "D" in the engine code
i think i've left something out but this new layout is hurting my eyes and i've got other net stuff that needs doing..
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 01-17-2006, 08:18 AM
^ I thought the japan models only came with rb engines... my fault
