Go Back   Automotive Forums Car Chat > Volkswagen > GTI
Old 01-16-2006, 07:56 AM
G-man422's Avatar
G-man422 G-man422 is offline
Thumbs up New R32
Have any of you seen the new R32? It looks great. you can chech it out at http://www.rapidcars.com/r32.php
Old 01-16-2006, 08:57 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: New R32
nice, if the new passat 3.2 is as fast as it is I cant wait to have a good rush driving the r32 that weighs prob 1000lbs less
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 01-29-2006, 03:25 PM
G-man422's Avatar
Re: New R32
Awww Yeahh!
Old 02-04-2006, 09:35 PM
catsman72 catsman72 is offline
Re: New R32
i saw in a mag that it might not get the 3.2 liter. the mag said that it might get the new 3.6 liter thats in the 2006 passat and if it did get the 3.6 it would be called the r36
Old 02-09-2006, 01:37 PM
pik_d's Avatar
pik_d pik_d is offline
Send a message via ICQ to pik_d Send a message via AIM to pik_d Send a message via MSN to pik_d Send a message via Yahoo to pik_d
Re: New R32
not a chance that the R32 (or R36) weighs anywhere close to 1000lbs less then the passat...
the passat 2.0T is ONLY 46lbs heavier then the jetta 2.0T comparing the manual versions of each 3259lbs for the jetta, 3305 for the passat... i know. shocked me too...
the passat 3.6 4motion (because we know the R36 will have the 4motion system, right?) is a heavy 3829lbs... (automatic, no manual version is available). so, adding the 4motion and the 3.6 V6 over the 2.0T adds 485lbs (comparing automatic transmission trims)... but with a shorter wheelbase the R36 should theoretically add less weight... so it of course wont be 3800lbs.
that, and from VW europe (who already have the 2006 R32), i found the "unladen weight" to be 1590kgs... which is 3505lbs. with the bigger 3.6L V6, it'll most likely weight a little more... so at most, the R36 will be 300lbs less than the 3.6L 4motion passat.
