Old 01-16-2006, 02:01 AM
1BadBowTie 1BadBowTie is offline
Send a message via AIM to 1BadBowTie
Question Headlight Switch
hey if I replace my stock 1999 headlight switch with a switch from a 2001, would I then be able to push the dome over-ride button in a few times and make it so i have control over my headlights??? my buddy has a 01 and if u push the botton in 4 times with-in 6 seconds the automatic head lights go out and you have control over it. so since the button for the over-ride and the headlight switch are in the same unit, couldn't i just get a new unit from a 2001-2003 and it would work?? or are the connections different or anything?
1998 K1500 Silverado 350 5-Speed
1999 Lumina LTZ
1984 Oldsmobile/Hurst
Old 01-16-2006, 06:17 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
Re: Headlight Switch
I would think that the truck's computer would control that not the actual headlights.
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 01-16-2006, 09:36 AM
chuck16's Avatar
chuck16 chuck16 is offline
I don't think if you replace the switch that the functionality will be there. Like Nigel says it's more about the Computer on board. If you want to bypass your Automatic headlights check out the wiring diagram in my gallery.
Cheers
Evan
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 01-17-2006, 08:29 PM
Tdragone Tdragone is offline
I told another 02 Silverado owner about the dome override thing; and he didn't know about it.
He was in the military; and when going on base (Dim lights) he would push his E brake down just enough to get the lights to turn out.
Not sure if you can then turn them on with the switch; but it worked for him.
Old 01-21-2006, 05:56 PM
airpanefixr's Avatar
airpanefixr airpanefixr is offline
the wire schematic doesn't show the lighting system going through the computer so it should work. Also, the e-brake thing doesn't work. i tried it the other day when i was going on base
Old 01-21-2006, 06:10 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
My headlights won't automatically come on if my e-brake is pushed, but I have an '02
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 01-21-2006, 11:00 PM
chuck16's Avatar
Unfortunately, when the e'brake is down even just a notch the bell dings continously if your in motion. Just bypass the automatic lights by wiring in a switch with a resistor of the light sensor wiring that goes to the BCM. If your trying to disable you auto lights.
2008 GMC ACADIA
I AM Canadian!!
Old 01-23-2006, 05:49 PM
jeep_cj4x4's Avatar
jeep_cj4x4 jeep_cj4x4 is offline
Send a message via MSN to jeep_cj4x4 Send a message via Yahoo to jeep_cj4x4
the e-brake thing is for pre '99. As for the swaping out the switch..., unless you change the wiring, as soon as you shut the truck off, it resets the lightswitch and you need to hit the dome overide again the next time you get in. Might as well let the truck turn them on when it wants and then turn them off when the need arises. I dont understand why everyone wants to control the lights manually anyway..... when it gets dark, you need lights... one less thing for you to do.
2004.5 Silverado 2500HD 4X4, LLY, Banks 6-gun/speed brake/intake, Dual bypass oil filter, 4" exhaust, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything!
84k miles/30NOV11
Yeasu 857D/ATAS-120A - "When all else fails..."
Old 01-24-2006, 07:33 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
You'll have to either change out the BCM (Body Control Module) with one from an '00 - '02, or have the '99 bcm reprogrammed at the dealer. Either way, the switch does nothing for this. You can use the 99 switch, you just have to have the computer altered. its located under the steering wheel.
I have a resistor wired in mine so they don't come on at all unless I turn them on. I completely unhooked the sensor on the dash.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 01-24-2006, 09:25 PM
CamelR CamelR is offline
It would be nice if you could easily overide the auto function. Say, if the light switch had "auto" "off" "running lights" "park" and "headlight" options. Also, in the auto mode there should be an indication of what lights are turned on. It's annoying when the operator is left out of the operating decision loop.
Old 01-24-2006, 09:32 PM
chuck16's Avatar
I have both options on mine. I wired my 1999 Silverado so that I could have it in Auto mode or bypass the Auto setting and use the switch. (Complete Control!)
I wired a micro switch to the BCM that Parallel's the light switch.
Like this:
I have Green Leds in my headlights and the only way to view them at night is to override the Automatic Headlight function. So I flick the toggle switch and all my lights shut off and the Green LeDs are apparent.
If you need help or have any other questions let me know...
Evan
2008 GMC ACADIA
I AM Canadian!!
Old 01-24-2006, 10:01 PM
Like this:
Evan
I've got one... Are you an electrical engineer?
Old 01-24-2006, 10:49 PM
chuck16's Avatar
LOL.... nope just a car nut with a an arsenal of Electrical friends who are great people to bounce questions off of...
2008 GMC ACADIA
I AM Canadian!!
Old 01-25-2006, 07:34 AM
jeverett's Avatar
Hmm. I'd like to add the switch to mine. I have the resistor wired in with mine and they stay off unless I want them on....
But I guess I basically have the same thing...w/o an auto option of course
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
