Old 01-15-2006, 08:32 PM
trypodd's Avatar
trypodd trypodd is offline
Exclamation number 2 randum missfire on 1988 blazer
i have replaced almost everything i can think of yet the number two cylinder
keeps missing spuraticly ive replaced the cap and rotor the plugs & wires, and
the coil which helped a little. i also did the timing and reset the ecm it still is missing im trying to figure out if its a ecm problum or if my distrubuter is going bad. need help pleas!
Old 01-16-2006, 03:48 PM
maxwedge maxwedge is offline
A990 racer
Re: number 2 randum missfire on 1988 blazer
How have you pinned it down to #2?
Old 01-16-2006, 05:55 PM
Jeremy Fitch Jeremy Fitch is offline
Send a message via Yahoo to Jeremy Fitch
plugs, wires, dist cap, rotor button, coil? all been checked or replaced?
Old 01-17-2006, 02:10 PM
trypodd's Avatar
i took my timing light and put the pickup leed on each plug wire the number
two plug only lightes the gun in spurtes. and yes i have changed cap roter wires plugs coil and ecm to date the ecm helped but it is still missing at least two out of every ten fires.
Old 01-17-2006, 04:00 PM
Mr. Smith Mr. Smith is offline
Send a message via Yahoo to Mr. Smith
If you have bosch plugs in it swap that plug out with a known good plug and see if the problem goes to the cylinder you swaped it too. Bosch plugs are crap and I discourage their use. AC or Champion get the nod..YMMV
