Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-15-2006, 08:10 PM
truc0011 truc0011 is offline
Cleaning the Lower intake gasket contacts
I assume one has to be careful when cleaning the old intake gasket off the engine when replacing? What does everyone use???? I was thinking of using a razor blade but someone told me the aluminum was too soft for that?
Thanks for the Info!!!
Old 01-16-2006, 05:48 AM
cdru's Avatar
cdru cdru is offline
Re: Cleaning the Lower intake gasket contacts
If you are careful, you can use a razor. But what someone said is true, the razor is harder then the cylinder head and you can scratch/gouge it. A plastic scraper is better. Some acetone or brake cleaner will finish up the job.
Vinyl adds horsepower, right?
