Old 01-15-2006, 07:57 PM
SuperStock96 SuperStock96 is offline
Dyno Advice
I am getting my car on the dyno next week and I am wondering what things I can do to help produce better numbers. Is there anything that will make any difference whether it be minuscule or not. Someone told me to change the oil the day prior but that doesn't seem like it would matter. I plan to run 100 octane in the car and put in fuel injector cleaner to make sure I am spraying well.
Do I just sound retarded?
Just a bit better than stock: Berk Intake w/ Apexi Filter, Cattman Y-pipe, FastCat, Cattman Catback Exhaust, TS ECU, Various Lighting Changes.
Old 01-15-2006, 08:08 PM
DetroitMuscle's Avatar
DetroitMuscle DetroitMuscle is offline
Send a message via AIM to DetroitMuscle Send a message via Yahoo to DetroitMuscle
Re: Dyno Advice
100 octane in what?
That wont give you more power unless the motor is built to run on that, itll actually not burn completely and cost you power, stick with 93 or 89/91.
The oil will help quite a bit more then 100 octane will, the fuel injector cleaner sounds good but put it in a week or two ahead of time and let it work its way back out before you test.
Old 01-15-2006, 08:19 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Dyno Advice
unless your car is tuned for 100 octane or your car is detonating, 100 octane will do absolutely nothing. In fact, it may even hurt performance since it burns slower.
This is a very hard question to answer since we dont know what car you have or what mods you have or are available for your platform. Im guessing your not looking for answers like buy an exhaust system, nitrous. Somethings you can do though, is clean the intake manifolds/heads from all the carbon build up. Disassemble them and clean them with some Berrymans B12 cleaner. Im not sure, if you have an intake kit or anything on the car, but make sure the intake piping is as straight and level as possible. You dont want any turbulent air flowing into the engine. You could optimize the throttle body which consists of removing one side of the throttle body shaft, flush mounted screws, and knife-edged throttle body plate. Im sure theres more, but your question is very general.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 01-16-2006, 07:05 AM
Re: Dyno Advice
OK, here's the situation. I am driving a 2003 Nissan Maxima with the 3.5L. I have had Cattman Y-pipe, high flow cat, Cattman Exhaust. The airbox has been replaced with a Berk Short Ram intake with the A'pexi power filter. The exhaust mods have about 6k miles on them and about 2,000 on the intake
The car has 46,00 miles on it and ran 184hp with just a K&N panel air filter. I have been using Mobil1 for the last 20k miles and run an injector cleaner with every other oil change. Is there an oil filter that is better than others?
Old 01-17-2006, 12:49 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Dyno Advice
why are you getting dynoed?? Are you getting tuned...because if not i think its kind of a waste unless you just want bragging rights, but even then i don't think you're going to have much....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-17-2006, 04:29 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Dyno Advice
so he can se that his y pipe an SRI are really giving hime that extra 7hp
Old 01-17-2006, 05:14 PM
Schister66's Avatar
AF -Advisor
Re: Dyno Advice
and a $100+ dyno run is soooo worth that!
Old 01-18-2006, 04:33 PM
Re: Dyno Advice
3 runs on a dyno for $45 to see if my $1300 parts are running the way the manufacturers say they do is in fact so worth it. I also want to see how rich or lean the car is running on paper. Having numbers is pretty important to me.
Old 01-18-2006, 10:23 PM
bigirb2002 bigirb2002 is offline
Send a message via AIM to bigirb2002 Send a message via MSN to bigirb2002 Send a message via Yahoo to bigirb2002
Re: Dyno Advice
when your in your last gear floor it
Old 01-18-2006, 11:02 PM
Schister66's Avatar
AF -Advisor
Re: Dyno Advice
and exhaust and intake cost you $1300?? WOW!
Old 01-19-2006, 04:01 PM
Re: Dyno Advice
Yeah, I know I could have saved a few dollars and sacrificed some power, but I wanted the most the market had to offer without making a custom set-up. I don't have THAT much money.
