Old 01-15-2006, 07:57 PM
jdcarnathan jdcarnathan is offline
quick newby question
i just installed a hks type 1 boost controller in my '92 stealth rt/tt and had to unplug the ecu, the car is idling rough and dying at intersections, does it just take time for the ecu to learn to idle again or is something seriously messed up. sure would appreciate it,
Old 01-15-2006, 08:14 PM
DetroitMuscle's Avatar
DetroitMuscle DetroitMuscle is offline
Send a message via AIM to DetroitMuscle Send a message via Yahoo to DetroitMuscle
Re: quick newby question
Is the check engine light on?
It should have to relearn it, especially since its a preprogrammed computer.
Old 01-15-2006, 08:49 PM
no check engine light on, does it someone told me it just takes a while for the ecu to learn to idle again, is this true
Old 01-15-2006, 10:09 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Even though yes the ECU must relearn some parameters it shouldnt be stalling. Did you plug everything back in? Like the MAS, all vac lines etc? Is it an open atmosphere BOV? If so that also could be your issue.
Old 01-16-2006, 10:39 AM
everything is plugged back in and all vacuum lines are good, how long does it normally take the ecu to learn again
Old 01-16-2006, 10:43 AM
Morphius289's Avatar
Morphius289 Morphius289 is offline
It sometimes dies if you unplug it. It will be around 1-2 days until your car returns to normal.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 01-16-2006, 10:48 AM
ok thanx, i noticed if i kinda ease around not using boost or anything too much it does better, but if i get on it really hard and have to stop really quick it does it, i had this problem before but it went away, just wondering if anyone else experiences this as well
Old 01-16-2006, 07:03 PM
AutostradaVR4 AutostradaVR4 is offline
as stealthee said, do you have an open atm. blow off?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 01-16-2006, 09:29 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
^That's what I'm getting at too, you may have to install an AFC to even things up.
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
